02-16-2023, 09:30 PM | #1 |
Drives: 2015 Green Flash Join Date: Oct 2018
What is high mileage on a ss?
I’m starting to look for a new to me 2016-2018 ss (most likely automatic) and I am only finding cars that have a few more miles than I normally would consider so I am curious to when (mileage) the problems start to come up on 6th gen Camaros. Thanks in advance!
02-16-2023, 09:46 PM | #2 |
Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
My 2018 is still at a low mileage, but from what I've seen here the only considerable, universal issue is the A8 transmission shudder that can surface at any mileage but has a well-known solution (see here). Other than that, the powertrain is stout and should last long, provided the owner does proper maintenance (oil changes primarily).
There obviously are other potential issues such as the rear axle moan or NPP exhaust rattle, but these are smaller, very easy to remedy and typically make an appearance during the first few thousand miles, so I'd imagine the previous owner would've got them fixed.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 |
02-16-2023, 10:45 PM | #3 | |
Drives: 17' Chevy Kamaro SS 6 speed Join Date: Mar 2022
Hoping 150-200k miles, which is good for a car being run hard and slammed through the gears. Mine is a 17' SS manual with 61k miles. Still runs like new. Last edited by Casper the friendly G; 02-16-2023 at 10:47 PM. Reason: gg |
02-16-2023, 10:45 PM | #4 | |
Drives: 22 Camaro 2SS A10 Join Date: Jul 2010
With used car pricing the way it is now, you might as well buy new.......
2022 Camaro 2SS A10
2007 Trailblazer SS |
02-17-2023, 01:30 AM | #5 |
Drives: 2018 Camaro SS Join Date: Jan 2021
I believe 14k is average. I would be OK with anything in 8-10k per year. Don’t be worried about secondary market.
Everyone assumes that it was tracked everyday by an unassuming teen. Reality is most people who buy them, they are the most expensive car they own. I bought a 18 with a ProCharger which when people here assume this guy drove 100 mph at 7k rpm’s everytime he was in it. People may drive it spirited but are gonna take care of a 35 to 50k investment. Sent from my iPhone using Tapatalk |
02-17-2023, 07:36 AM | #6 |
Shadow Gray '19 ZLE M6
I wouldn't be too scared of mileage -- I'd care more about good service records, regular oil changes, other fluids flushed / changed at regular intervals, etc. A well taken care of high mileage car will have more longevity than a neglected lower mileage car.
And keep in mind these pushrod, overhead valve engines are not overly complex -- and GM LS / LT motors have pretty great history of reliability and relatively low cost of repairs. I'd figure out your budget, see what mileage SS that budget can support in the market and then find a car that comes with paperwork, documentation, maintenance history, etc.
2019 ZL1 1LE | M6 | SGM | PDR | CF Dash | Nav | Wheel Locks
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
02-17-2023, 07:56 AM | #7 | |
Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
02-17-2023, 08:12 AM | #8 |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
Well cared for V8's are designed to go 200-300k miles. High mileage would be 100k+. Most factory parts begin to wear at 100k miles such as radiator, fuel pumps, Alternator etc.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
02-17-2023, 11:36 AM | #9 |
Banned
Drives: 2018 Camaro SS1 1LE Join Date: Feb 2017
63k + and zero issues, zero added oil between changes.
02-17-2023, 11:49 AM | #10 |
Drives: 2023 Sharkskin 2SS Join Date: Oct 2022
02-17-2023, 11:54 AM | #11 |
Drives: 2023 ZL1 A10 Join Date: Nov 2021
Get the lowest mileage, with service records, you can afford.
2023 ZL1 A10 Shadow Gray Metallic
02-17-2023, 12:39 PM | #12 |
Drives: 2017 Hot Red 2ss Auto adrenaline Join Date: Aug 2017
Avoid the A8 at all costs, the fix is a stop gap and hides the issues underneath
02-17-2023, 01:19 PM | #13 |
Drives: Chevy Camaro Join Date: Apr 2020
Normal mileage on a 2016 car daily driven, would be in the high 70,000s/low 80,000 mileage range. most people drive around 12k a year) the camaro is built to be daily driven. A 2016 car is 7 years old now. Find one that isn’t a daily driven and has a maintenance history with it.
02-17-2023, 02:01 PM | #14 |
Drives: 2022 Camaro 1SS 1LE Join Date: Sep 2022
1. +1 to the advice about avoiding 8-speed.
2. Never trust the odometer, especially if there are no service records from the trusted source. 3. As for any performance enthusiast car, mileage doesn't mean a lot. It is not a truck with 200k of highway miles, and not an SUV where it is rarely abused. 4. Check the car yourself. Again, this is Camaro, not Chevy Equinox. One owner was doing burnouts daily, but has just 20k miles. Another owner was doing proper maintenance and took a good care of it, but the car has 60k miles. I will choose the 2nd one any time of the day.
2022 Camaro 1SS 1LE Rapid Blue 6MT
Looking for traction on wet pavement in Seattle. |
