07-27-2016, 03:39 PM | #1 |
Drives: 2018 Red Hot ZL1 Convertible Join Date: May 2016
Where to mount throttle controller
Don't really want to debate the merits or de merits of the Vitesse Throttle controller but would like to see where and how you mounted yours
Thanks |
07-27-2016, 03:42 PM | #2 |
Drives: 2011 Camaro 2SS/RS LS3 Join Date: Aug 2013
I have mine in the little spot right between the tach and the speedo above the steering wheel
2015 Silverado Z71 6.2/2011 Camaro 2SSRS LS3/2014 Cadillac ATS 2.0T
07-27-2016, 04:58 PM | #3 |
Banned
07-27-2016, 05:34 PM | #4 |
Don't have an actual picture of it but it can be seen in this one. Mounted mine on the voltage reading on the cluster thing.
07-27-2016, 05:44 PM | #5 |
Kyrac
Drives: 2018 2SS A8 Join Date: Feb 2015
I have mine mounted right above light switch, behind blinker switch so I can't see it during normal driving unless I lean to the left... Works out perfect, easy access if I need to change settings but out of sight, out of mind when I don't!!!
07-27-2016, 05:48 PM | #6 |
9 Year USMC Vet
Drives: 2014 1LT black on black Join Date: Nov 2015
Down on the console by my right knee. Not on the side where I can bump it.
Sorry, can't find my pic
A lot of stuff done so far to make it look better and be more fun to drive.....
07-27-2016, 05:52 PM | #7 |
Drives: 2012 2SSRS Join Date: Jul 2013
Money may not buy happiness, but I'd rather cry in a Chevy than in a Ford!
07-27-2016, 05:57 PM | #8 |
Drives: 2010 1SS RS M6 Join Date: Jan 2015
Before I even opened the thread I knew someone would say that lol
Vararam intake, gmpp exhaust, borla stainless long tubes, cat less, jannetty tune, bmr lowering springs, heritage grill , smoked lenses
07-27-2016, 06:28 PM | #9 |
Account SNAFU
Drives: 13 Tahoe 79 Scout II 15 1LE Join Date: Sep 2008
I mounted mine in the little spot right behind the wiper stalk. It's where the HUD controls go.
Sent from my campfire using smoke signals |
07-27-2016, 08:15 PM | #10 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Same here. Easy to see and change the setting it you need/want to...
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
07-27-2016, 08:21 PM | #11 |
Resident nomad
Yea, he-he, but the OP specifically said he didn't give a hoot about whether or not you thought the TC was garbage or not. Not have enough self-control to resist the urge to respond with that? I could care less that you think it's a garbage mod, but I think it kind of sucks that you think you had to share that in this thread.......
Sold:
07-27-2016, 09:45 PM | #12 |
9 Year USMC Vet
Found my pic..
I think this is the perfect spot.. I can see it, reach it and the wire is almost invisible
07-27-2016, 09:47 PM | #13 | |
Drives: 2014 2SS/RS CRT Join Date: Apr 2014
The cable is run up from underneath the steering wheel and it's just resting on top of the steering column in a little niche just in front of the dash. Totally out of site and unobtrusive but still very accessible if I want/need to change the settings.
Lifetime Camaro guy. 1979 Z28, 1987 LT, 2012 2LS, 2014 2SS/RS
--CAI Cold Air Intake --Solo HFC |
07-27-2016, 09:47 PM | #14 |
Chick Racer
Drives: 2017 50th 2SS Join Date: Dec 2012
I have mine mounted in the center console.
Thread Tools | |
