10-13-2020, 08:25 AM | #1 |
Found this in my oil pan
Just trying to see if anyone else has any idea what this is. I thought maybe a bearing, but it doesn't seem round enough and their are no notches at the ends to connect them to another bearing. Also seemed to thin for a bearing. Ideas would be much appreciated.
10-13-2020, 09:18 AM | #2 |
It don’t come easy.
Perhaps a spacer or bushing material?
10-13-2020, 10:11 AM | #3 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
looks like an ls3 timing chain dampener to me.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
10-13-2020, 10:43 AM | #4 |
Yep it's the spring for the timing chain dampener
10-13-2020, 02:04 PM | #5 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
More to come. |
10-13-2020, 02:56 PM | #6 |
Time to pull the timimg chain cover if you haven't done so already. Exactly why I went to the older style damper.
https://amzn.to/3jVtywF
10-14-2020, 08:29 AM | #7 |
Thanks everyone. That made it easy. I'll dig into that here soon.
10-15-2020, 03:34 PM | #8 |
Drives: 2014 1ss camaro Join Date: Jul 2017
how the heck did it get in your oil pan?
10-15-2020, 05:07 PM | #9 |
As soon as they pop loose they can fall right down into the pan, if lucky. The front of the pan on the LS is right underneath the oil pump, which is right under the tensioner.
I have seen a few where that clip pops out and gets wedged behind the upper timing gear and creates carnage. Falling into the pan is probably the best scenario. This is one of the main reasons we switch to the dog bone LS2 style. No moving parts.
10-15-2020, 05:25 PM | #10 |
Drives: T Join Date: Mar 2015
glad i saw this thread! Ls2 style it is LOL
10-16-2020, 10:32 AM | #11 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Mine fell into the pan as well thankfully. No issues, just noticed something was blocking the oil from coming out of the drain hole one day
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
