10-28-2018, 05:29 AM | #1 |
Supercharged 2012 ss
Hi guys I have recently finished building my 12 2ss to lsa. I will include all parts at the end of thread. I'm having a problem. Chopping start and when boost comes in the car falls on its face on the dyno and stand still rev. I have installed a fore innovations duel pump fuel system and it reads 58lbs before boost and 62 during boost. I'm at a loss as well as my tuner any help would be appreciated.
Texas speed stage 3 blower cam Fully ported blower manifold and snout. 2.33 upper pulley Nick Williams 102mm tb 1000 cc injectors |
10-29-2018, 02:46 PM | #2 |
Angewendet Ingenieur
Drives: 14 Camaro ZL1 Join Date: Apr 2015
Fuel pressure is fine. Have you tuned for NW?
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah. |
10-29-2018, 03:05 PM | #3 |
'It's an experiment'
Also are you sure the boost valve is adjusted correctly?
https://www.camaro5.com/forums/showt...nt#post8290240 Also only 1 vacuum line on the boost valve as the other line can shut off the valve. Which version of the NW 102 do you have? The NON-SC versions have been known to suck shut and stumble... that model # is: SD102MMEL: (DON'T want this one) https://www.summitracing.com/parts/nwp-sd102mmel You want the SC version (SD102MMSC): https://sdparts.com/i-24080932-nick-...lications.html as it has a stronger motor to prevent the sucking shut of the throttle blade... I have the NW 102 SC version and RPM's 5" CAI -- tuned by ABADZL1 and myself... No issues running that combo... Need to dyno again -- added meth too... -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 Last edited by hammdo; 10-29-2018 at 03:21 PM. |
10-30-2018, 06:07 AM | #4 |
Hey don thank you for the reply I'm not sure what version it is I bought it used from another Camaro guy. I'm gonna try bolting on my factory throttle body to see if I can at least get a pull out of it Thanks for the suggestion and I'll let you guys now
11-03-2018, 01:28 PM | #5 |
Tried the factory throttle body and same issue. I'm at a loss
11-05-2018, 01:57 PM | #6 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
Which brand injector? Did you load the injector data? Do you have the tune file?
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
11-05-2018, 02:04 PM | #7 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
If you're data logging, you should be able to see what's happening, like throttle closing, fuel or timing cut, etc.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
