05-02-2020, 03:30 PM | #1 |
Drives: 2016 Mosaic Black Metallic 2SS Join Date: Jan 2019
How do I remove metal subframe brace?
Hey guys. I have a 2016 SS and am pretty sure I'm leaking oil from the oil pan bolts. I've tried searching online on how to remove the metal subframe brace but unfortunately can't find anything. Are there instructions on how to remove the metal subframe brace so I can gain access to the oil pan bolts to tighten them? I see how and where to remove the plastic pieces, but the subframe brace I'm not too sure of. I don't want to go unbolting the wrong thing and end up causing a bigger problem. Any tips help! Thanks.
05-02-2020, 07:06 PM | #2 |
Drives: 17 hyper blue 2SS M6 Join Date: Mar 2018
Just take the bolts out and it'll drop down, hinge on the front. If you're on jackstands just bend that hinge and it'll drop off. Piece of cake, easier on a lift of course.
05-02-2020, 08:09 PM | #3 |
Sorry if this is a dumb question, but all these bolts in green need to come out so I can take this off to access the oil pan bolts? Pic attached
05-03-2020, 01:07 PM | #4 |
yes, just take them all out, it'll hinge on the front, super simple after you've done it once.
05-03-2020, 07:40 PM | #5 |
Thanks! I totally forgot you said I could bend that hinge. I was on raceramps so I couldn’t get the whole thing completely off so I tightened what I could with it hanging in my face lol. You can actually bend the metal hinge piece without breaking it? If I’m still leaking oil I’m gonna have to try that
05-03-2020, 08:54 PM | #6 |
It doesn't really do anything, you can definitely bend it. I'm about to take mine off again, it'll probably break off soon.
