Jason 98 TA
Old 09-16-2018, 10:30 PM   #1
623
Drives: Black a/c radio
Z/28 Transmission fluid quantity
I am going to change out the transmission fluid in the Z/28 The owners manual specifies 4.5 qts for the quantity. I drained it and only 3.8 qts came out the rear drain plug.
The car is level and the fill plug was removed.
Am I missing something?
623 is offline   Reply With Quote
Old 09-16-2018, 10:48 PM   #2
Zslash28
Jumanji
Zslash28's Avatar
Drives: '14 Z/28 - AGM - No A/C
There is residual, that wont come out. I experienced the same thing. I then employed the ole aircraft maintenance technique of "fill to spill". All good after that.
Keeper of the 5th Gen Z/28 Registry.
Registry Facebook.
Follow: @5th_gen_z28_registry
I track wrecked Z/28s Total lost -41
Zslash28 is offline   Reply With Quote
Old 09-17-2018, 09:00 AM   #3
j o n
j o n's Avatar
Drives: 2015 Z/28 #00048
When you refill, you fill till it seeps from fill plug, that's how you know it's full. So make sure it's level or at least higher on fill plug side of trans
Current:
'15 Z/28 #00048 | White | A/C | Speakers | Michelin PS4S 305/30/19's
'17 Ridgeline RTL-T | AWD | White | Ebony | 20" MDX Advance wheels
'16 CR-V EX-L Navi | AWD | White | Ebony
https://www.instagram.com/__jon__athan__/
j o n is offline   Reply With Quote
Old 09-17-2018, 02:18 PM   #4
623
Thank you for the quick and helpful replies.
That is what I was hoping the answer would be. It took the same amount +- a few ounces to overflow from the fill port.
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
