11-12-2014, 06:40 PM | #1 |
Got mine!
Drives: 2021 LT1 RS - Orange Crush Join Date: Mar 2011
brakes slightly squeaking
I only really notice this in the evenings when leaving work. I've got about 60K miles on her. I am experiencing a rather slight squeak from the brakes in the evening. Is this just because its cooler out? Could it be the wear indicators? If it is the wear indicators why wouldnt they squeak once we get things warmed up? I don't want to ignore it if it is the indicators. Helpful advise preferred.
Camaro lover since 1984 when I got my first car a 1978 Camaro LT with a 2 barrel carb on 305 V8... yes I put in a 350 with a 4 barrel.
11-13-2014, 12:03 PM | #2 |
Got mine!
I guess this is a no-brainer if no one answering. Just curious for some insight.
11-13-2014, 12:44 PM | #3 |
It could be a number of things; warn out pads, debris caught in the pads, not enough grease, glazed pads. At 60K you're probably getting close to the end of their life anyway, but the only way to know for sure is to check them out.
Best regards, Tyler 888-308-6007 |
11-13-2014, 12:47 PM | #4 | |
Got mine!
Thanks Tyler... Best advise so far. I appreciate it.
11-13-2014, 12:51 PM | #5 |
Drives: 2010 2SS IOM L99 Join Date: Jan 2010
if i had 60m on my pads i would have them changed.you are close to the end for your old ones.don't want them to get into the rotors.i would have them replaced with ceramic pads.it will cut way down on brake dust.
11-13-2014, 05:55 PM | #6 |
Got mine!
Will do. Thanks for the tip Ron!
