Old 08-14-2015, 07:00 AM   #1
SunnySideUpII
SunnySideUpII's Avatar
Drives: 2015 ZL1 Bright Yellow
Engine bay - what to cover
Hi all,
I want to give my engine bay a good wash after a few months of driving the car.
I know pretty much what the drill is. I've got a pressure washer which is not too strong, got the all purpose cleaner and the brush for agitation, etc . and I know the dressing is optional.
I just would like to know "specifically" which parts I need to cover on a ZL1 engine bay? I know as a general rule, air filter and electronics should be covered/isolated. My engine bay is so far completely stock, so my air filter is not exposed. Apart from that, I don't know which electrical parts I need to cover.
Can someone point me in the right direction please? If anyone has any photos of their engine bays prepared before a wash, that would be awesome.
Thanks a lot.
SunnySideUpII is offline   Reply With Quote
Old 08-14-2015, 09:03 AM   #2
rjs2010SS
rjs2010SS's Avatar
Drives: 2013 AGM ZL1 BELLA*
Honestly... I just took the hose and sprayed all around the engine bay, but nothing directly on the motor... just mainly hit it to knock the dust off.... then I took some detailer and a nice rag and went over everything..It looked good to go after that.
Roto Fab CAI, Roto Fab Big Gulp, Jokerz ported SC/Snout, LS7 TB ported, ATI Balancer, 28%(10") Lower Pulley, 2" Headers, No Cats,Forza 3way, E85 Flex Fuel sensor , ID850 injectors,, BTR Stage 3, Ron Davis HX, Mighty Mouse CC, APR Splitter, Aero Sports Concepts Splitter Kit, Showstoppers CarbonFiber wicker bill, MRR Wheels. 720rwhp/690tq on 93, 762rwhp E85.
2013 AGM ZL1 Bella*
2010 MGM Toyota Tacoma
2010 CGM SS (Traded)
1996 Black SS (Sold)
rjs2010SS is offline   Reply With Quote
Old 08-14-2015, 10:29 AM   #3
Dimitrim
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1
Originally Posted by SunnySideUpII View Post
Hi all,
Thanks a lot.
Don't do it...Water is your worst enemy. Just wipe it down with some rags.
Dimitrim is offline   Reply With Quote
Old 08-18-2015, 04:06 PM   #4
revobasher
revobasher's Avatar
Drives: 2013 ZL1
^^^ agree.. I use a little Megs Quick Detailer and microfiber cloths
2013 ZL1 - Blue Ray Metallic
JDP 850 Package
740hp/700tq @14lbs on E85
Build Thread
revobasher is offline   Reply With Quote
Old 08-18-2015, 05:10 PM   #5
2013 ZL1 #7860
Drives: 2013 ZL1 A6 #7860
Engine bays are not weather tight... Just spray it off and whipe it down.
2013 ZL1 #7860 is offline   Reply With Quote
Old 08-18-2015, 09:19 PM   #6
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
I don't cover anything.
just don't spray directly into any electronic stuff or wiring; just hit those with a quick once-over and you will be fine.
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 08-18-2015, 09:43 PM   #7
CRF8
Space Coast Camaro's
CRF8's Avatar
Drives: 2017 Camaro SS / 1974 Firebird 400
"Engine bays are not weather tight"... well from the bottom they may handle water ok. However, the top of the engine is designed to have a hood and an engine cover over it.
There is NO way I would use a pressure washer or hose.
Hyper Blue 2017 Camaro 2SS, MRC, dual mode exhaust, window tint
SOLD: 2014 Camaro 2-SS red rock metallic,
named "Waste of Money" by the wife,
RS package, 93 tune, front strut brace, window tint, Lloyd's trunk mat, cargo net & organizer, LED blue dome & trunk, BMC fade gills, RotoFab CAI, Granatelli axle back, Gorilla wheel locks, Expel headlight protectors,V-max throttle body.
http://spacecoastcamaros.com/scc/index.php
CRF8 is offline   Reply With Quote
Old 08-19-2015, 01:14 AM   #8
SunnySideUpII
Thanks for the advice guys.
Old 08-19-2015, 01:50 AM   #9
2013 ZL1 #7860
The hood is not sealed... Your engine is wet in heavy rain.
Old 08-19-2015, 07:01 AM   #10
SunnySideUpII
You are right the hood is not sealed, but I guess the water goes into the engine bay only through the edges of the hood and the carbonfiber vents, and in all cases water is redirected through some dedicated lines/canals away from the engine. Even in heavy rain, the engine itself and the components would not get as wet as they would when you spray water directly on them.
I am more inclined to avoid using the pressure washer now, but I might do a quick light spray (mist).
