04-15-2018, 11:35 PM | #1 |
SS
BTR stage 3 HP number before and after
Well got my base line and final number today I pick up the car and dyno sheet on saturday so just a bit longer lol
base dyno was 419 hp thats CAI intake Bo White ported throttle body JBA shorty headers Solo high flow cats and npp exhaust great number for no tune! and now tuned btr cam and long tube Kooks 1 7/8 " headers and high flow cats its a healthy 463 HP can not wait to drive it but Davenport is in Calgary and they are getting the final blast from Montana 10" dump of snow the number is healthy but the gains from the three things wasn't as much as what i have read on others my thoughts are that its going to be very drivable
CCW sp16a track set, BTR stage 3 cam and kooks longtubes with high flow catsLocks@7.5 degrees castor and radius arm inserts, Ride Tech 2coilovers JDP upper control arm bushings BMR lower knuckle bushing Bo White throttle body3.91 gears Spohn del-sphere toe link and trailing arms Prothane subframe bushings
04-16-2018, 12:51 AM | #2 |
Drives: '18 SS 1LE Join Date: Jul 2016
thats not bad at all.. when do you plan on tuning it?
04-16-2018, 06:46 AM | #3 |
SS
It was tuned and installed at Davenport Motors in Calgary. its the first time that I have thrown the key and walked away, actually flew to Hawaii to get a break from this record breaking long winter haha
04-16-2018, 08:14 AM | #4 | |
GPI Sales Consultant
Got a question about a GPI product? Feel free to shoot me a message! |
04-16-2018, 11:43 AM | #5 |
S1N1STR
I am almost exactly the same with the BTR stage 3. I think 464 if I remember right?
Sent from my iPhone using Tapatalk Pro |
04-16-2018, 02:14 PM | #6 |
SS
Cool seen that number range a fair bit some guy on YouTube is getting 470 with27.5 degrees advance not sure what mine is yet but 28 degrees was hitting the knock sensor 1320 maybe... lol, lots of hwy in my area main plan is the Badlands motorsport resort it's a soon to be built track 3 hrs away with a bigger corkscrew than Laguna Seca's already put in adownpaypyment on a life time membership
04-16-2018, 03:56 PM | #7 | |
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85 Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE 10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake Best 1/8 6.80@105.75 Best MPH 134.82 |
04-16-2018, 05:52 PM | #8 | |
Drives: 13' 1LE Join Date: Apr 2012
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
04-16-2018, 07:32 PM | #9 | |
Drives: 2011 Camaro SS Join Date: Nov 2014
04-16-2018, 09:20 PM | #10 |
Drives: 2014 Camaro 1SS Join Date: Jun 2010
464 here as well
2014 1SS - BTR Stg3, GMPP CNC Heads, Kooks LTs & cats, Magnaflow 2.5" Street w/Res X, Z28 CAI
04-16-2018, 09:33 PM | #11 |
I made 478rwhp with ported heads so your right where you need to be. Good power
04-16-2018, 10:09 PM | #12 |
SS
good to know guys thanks, and Bo that pre tune/cam build was awesome n#s you sir are a part of that also!
04-17-2018, 06:49 AM | #13 |
I made 476 with my bolt on set up and trapped 95 1/8 120 1/4. Sounds like you have some mph left there. Same set up on my C6 traps 98 1/8 and 125+ 1/4 but this was on stock exhaust still.
04-17-2018, 07:26 AM | #14 |
Mine traps 89mph in the 1/8th with 412rwhp -basic bolt ons. I agree with lazerlemonta that you've got some left on the table for sure.
