04-18-2018, 04:10 PM | #1 |
Drives: Camaro 45th A. E. Dragster Join Date: Sep 2012
TR6060 to TH400 swap n/s switch issue
Hey guys... I did a TH400 swap and need to know how I should wire the neutral safety switch into the ignition switch to work correctly... I tried all 3 cables and I always could start in gear...
Thanks for any help, Björn |
04-19-2018, 12:06 AM | #2 |
Purple wire off the starter. Cut it and interrupted with your shifter. Just did that part of my TH400 swap today lol.
There is no neutral safety switch on the M6 cars. |
04-19-2018, 03:39 AM | #3 |
I know, I tried it with the wires of the ignition switch, but nothing worked ... now I will use this purpble/white form the starter relay
04-19-2018, 05:57 AM | #4 |
It works fine
