02-28-2017, 11:56 AM | #1 |
GPI Sales Consultant
170*F T-stat?
Ever hear of a 170*F T-stat for an LS3? When I bought this car the previous owner told me it had a 170*F T-stat. The car runs pretty rock solid regardless of ambient temperature at 174-178*F, so I accepted this as fact. The more I've spent time on this site and in the LSx world the more I'm lead to think it's probably a 160*F T-stat, which is far more common.
I'm happy with how it acts - 175*F is about the minimum threshold for engine temperature without adding undo wear. Oil temp runs right around 210*F when warmed up under cruising conditions, which is spot on. The car is tuned for the T-stat, it cycles the fans when sitting still to keep it under 180*F on all but the hottest of days. Never have seen the coolant over 185*F. If this is a 160*F stat it must settle out quite a bit higher than the stat rating. I guess that makes sense as every car I've had usually runs about +10-15 over the T-Stat value. Just curious if some of you guys with 160*F stats can comment on the coolant temps your cars settle at.
Got a question about a GPI product? Feel free to shoot me a message! |
02-28-2017, 12:51 PM | #2 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
Very common to see those Temps with a 160 stat. Had a 160 on my 3rd. Gen and I saw it too.
02-28-2017, 02:45 PM | #3 |
Concur. I have the 160*, and I'm usually right in the neighborhood of 175-180.
-Scott |
02-28-2017, 02:49 PM | #4 |
Thank you gentlemen.
03-01-2017, 08:13 AM | #5 |
Drives: Camaro V6 Join Date: Oct 2016
170* is better though. It's just enough to keep you closed loop most of the time and still keep the crisp throttle response in higher ambient temps.
03-01-2017, 02:41 PM | #6 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
http://www.lingenfelter.com/product/...l#.WLcxm2QzUR8
They have a 174 if anyone wanted a compromise between stock and 160. |
