05-02-2023, 03:54 PM | #1 |
Drives: 2010 Camaro SS M6 Join Date: Mar 2023
Cam install
Hello all, please help. At my wits end 😂.
Finishing up my cam install. Oil pan is back up, valvtetrains done, Now of all things, the timing cover is giving me the hard time. The bottom bolts that go in the timing cover (2 of them) start threading but shortly after get immediately tight. I really don’t wanna break them off, I’m not sure why they are doing this. Thanks in advance. |
05-02-2023, 04:51 PM | #2 |
ZL1_Chris
Is it possible the pan is slightly off. Maybe try Loosening the pan bolts a little then get all the bolts started first
05-02-2023, 07:21 PM | #3 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Yeah, they should go in easily. Maybe the gasket is cocked. I would loosen the rest like he said, and start over.
05-03-2023, 12:36 PM | #4 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
Yeah I would loosen all the oil pan bolts just put the cover bolts finger tight, put your hormonic balancer on, spin the engine a time or two to center the cover with balancer, snug up the cover blots, and finally tighten your oil pan bolts. Anyways that's they way I do it.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
05-03-2023, 12:53 PM | #5 | |
Drives: 2015 zl1 m6 Join Date: Jan 2020
This is how I installed my timing cover , hopefully this vid will give you some insight
791whp 699 ft lbs torque on E30 - ported sc /heads by boost mode racing - PAT G cam /Tune
PB:10.7 @133.9 |
