09-07-2016, 06:58 PM | #1 |
Drives: 2012 camaro IPF supercharged V6 Join Date: Sep 2016
IPF supercharger pulley
Hi, all.
I have a 2012 IPF supercharged camaro V6. Few months ago, the belt of supercharger broke, and the installer says one of the pulley had a bad bearing in it causing the pulley not able to rotate anymore. Then, he replaced the new bearing and belt. Today, I went to auto repair and check my car. They found there is a dent on edge of pulley of my supercharger. I am not sure what the reason is causing the bad bearing or pulley. Is this because of the installer of supercharger, or something? he sucks? Any ideas or thoughts? I am going to have a long trip, and I just do not want the belt to break or my car break down again. Thanks, guys! |
09-07-2016, 07:14 PM | #2 |
Built Not Bought
Drives: 2010 Twin Turbo LFX Join Date: Jun 2016
there was a bad batch of bearing that they originally came with and ipf was supposed to send new ones to existing customers.. boco bearing makes a good replacement 6003 is the bearing make sure its abec 5 at least.. as far as belt go with a gotorback or continental same company really good belt.. as far as the pulley thats tuff to say could have been damaged when being installed who knows .. if you need another stock pulley for the charger itself 3.8 i have one has about 100 miles on it ill sell cheap
2010 Twin Turbo LFX
In Memory of my DAD Gone but never Forgotten 2014 "Built Not Bought!' Sponsors: OverKill Motorsports |
09-08-2016, 07:36 AM | #3 |
Drives: 2015 1LS Red V6 Join Date: Aug 2015
Post a picture of what you are having troubles with. A dent on the pulley wont be because of a bearing. But we can at least tell you if it could cause problems based on where its at
Sponsors:
Overkill Motorsport BCS Auto JacFab Machining APDEG Dream Gear Mobile Audio Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet 5th Gen V6 Performance Facebook Group |
09-08-2016, 08:02 PM | #4 |
09-08-2016, 08:06 PM | #5 |
09-08-2016, 08:14 PM | #6 |
Few months ago, the belt just broke, and the installer says one of pulley had a bad bearing in it causing the pulley not able to rotate, and then he replaced 2 new bearings. So I thought the pulley would be fine. But I checked my car yesterday, and it seemed the pulley is not good. Not sure what problem it is. By the way, I found someone says should install the upgraded idler pulley bearings(4 of them), but I only saw there are 2 pulleys com with 2 bearings. Do I need replace 4 of them? I just contacted KPE and ordered 2 upgraded pulley, and it come with 2 bearings.
09-08-2016, 08:47 PM | #7 |
Built Not Bought
yes 2 pulleys 2 bearings in each pulley .. looks like they seized and over heated .. kpe does a new version of the pulley not sure if the belt size changes because there bigger though.. what did he charge from the new pulleys ?
2010 Twin Turbo LFX
09-09-2016, 03:14 AM | #8 |
They are offering the new pulleys and corrected belt.
Sponsors:
09-09-2016, 09:18 AM | #9 |
Drives: 2013 Camaro 1LS - Ashen Gray Join Date: Jan 2015
wow...
"WIDOW" Overkill Edition w/Mace Cams,80mm tb,Jacfab spacer/ported intake,Alky Control,ARH off road pipes,SOLO custom system,3.91 gears, MGW,Phantom grilles,ZL1 appearance pkge, 3dCarbon vents, Lingenfelter hood and spoiler, PLX boost/wideband modules/gauge,ZL1 fuel pump,LF3 hpfp,DSS aluminum driveshaft,JPSS sway bars, Z28 replica wheels and CxRacing coilovers..
09-09-2016, 09:56 AM | #10 |
Built Not Bought
Cost?
2010 Twin Turbo LFX
09-09-2016, 10:35 AM | #11 |
I am not sure. Haven't been told the price but give Jay a call and he can get you all of the info. Sent from my iPhone using Tapatalk
Sponsors:
09-09-2016, 11:43 AM | #12 |
Built Not Bought
I I'll do .: still waiting for an invoice for the power steering adapter lol
2010 Twin Turbo LFX
09-09-2016, 05:51 PM | #13 | |
[IMG][/IMG] |
09-09-2016, 06:48 PM | #14 |
Built Not Bought
maybe these pictures will help makes sense of it ..here a top view one picture is with 1 bearing and the second is with both bearings "sandwiched" together
2010 Twin Turbo LFX
