10-10-2011, 12:31 PM | #1 |
Drives: 2012 black 2Lt + bells & whistles Join Date: Jul 2011
Vinyl Bowtie Help
If you have vinyl overlays, bow ties, side markers etc. where did you get them. I know there are numerous threads in this but I want new feedback. I saw bigworm videos and there's also chauffeur parts or something but those are the only two I know. If you did them yourself was it easy?
08/18/2011 (1100)(1102)(2000) 09/12/2011 (3800)(4000) (4150)(4B00) 09/23/2011 - (5000) |
10-10-2011, 12:33 PM | #2 |
Drives: 2ss/rs vr 6m Join Date: Mar 2009
walmart, less than 10 bucks, do it yourself, its easy.
10-10-2011, 12:39 PM | #3 |
Drives: 2011 Camaro 2LT RS M6 Join Date: May 2011
eBay... a ton of options and all are going to be cheaper than the pre-cut ones... just get some razor blades and you're ready to go.
10-10-2011, 01:07 PM | #4 |
Drives: 2011 IBM Camaro 2LT Join Date: Jul 2010
I went to my local business that makes signs....bought a 1 ft square of vinyl the color that I wanted for only $5.00 ....bought a x-acto knife, and that was all it takes. Did both front & rear bowties, and the small bowties on the tires too....and have some left over!!
10-10-2011, 01:13 PM | #5 |
Drives: 2011 LS White Camaro Join Date: Jul 2011
they sell em at walmart really?
10-10-2011, 01:48 PM | #6 |
I got mine at http://www.bigwormgraphix.net/camaro. If you use "Camaro21" as your coupon code, you will get 12% off !!
10-10-2011, 01:49 PM | #7 |
Drives: '10 2SS/RS, MKIII Supras Join Date: May 2010
Bought my vinyl at a hobby store for a couple dollars. Used a blade/xacto knife to make the cuts over the emblem. Wasn't too hard to do at all.
10-10-2011, 02:00 PM | #8 |
team chicklet camaro
Go to your local print shop/sign shop. I went to a Sign-a-Rama. I got mine for free. They have given me scrap. I've been back for more too. Free each time. They give me a sheet that's about the size of a sheet of paper, 8.5x11 inch.
To install, use a rectangular piece big enough to cover the emblem. Carefully stick to emblem, small air bubbles will go away with heat. With something like a credit card, run along the crease that exhists between the gold of the emblem and the Chrome of the emblem. After that crease is more prevelent from running the credit card along those lines, do the same thing with a fresh xacto-blade. Go slow and easy. Peal away excess, and all done.
10-10-2011, 02:35 PM | #9 |
v It bites.
Drives: 2011 IBM 2SS/RS Join Date: May 2008
Black10 ...hes a member here and when I jacked up one side marker he sent me the replacement free.
2011 2SS/RS
Performance: 439 RWHP: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit. |
Similar Threads | ||||
Bowties: Vinyl vs Paint vs Replacement Bowtie | JayDee | Cosmetics and Lighting Modification Discussions | 21 | 04-27-2015 07:30 PM |
DIY-Vinyl Bowties and SS/RS Inserts!!! | Ivan @ Southwest Speed | Camaro DIY & HOW-TO instructions & discussions | 101 | 11-07-2014 08:06 PM |
Wanting to Install Bowtie LED a different way | anglwngss | Cosmetics and Lighting Modification Discussions | 14 | 12-26-2011 09:34 PM |
Billet Bowties from ChevyMall | Angelina | Cosmetics and Lighting Modification Discussions | 9 | 10-06-2009 11:04 AM |
Bowtie Adhesive | AKcamaro | Cosmetics and Lighting Modification Discussions | 1 | 10-05-2009 09:53 PM |
