03-12-2021, 06:03 PM | #1 |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
LT2 Intake Manifold on Today
As the title says, I installed my LT2 intake manifold today. It really is a PITA to install initially, Should be a lot easier if I need to do it again though. 1st start up was good, a 7 mile aggressive drive was good also. Restart at home after checking stuff and tweaking harness connections , I got a cel. Drove it two separate times for a total of 25miles and still the cel is there. I need to borrow a scanner to see what code I have to determine problem. I also rechecked torque on all 10 intake bolts and it took quite a few turns to get them back to 75 in lbs, that bothers me. The car runs fine, but I do notice a slight loss in Idle RPM, may 50rpm, not even 100 rpm. Am using my stock air intake , that requires a little muscle to twist and stretch both ends and tightening the clamp to keep it where you want it. Various plastic vacuum lines need to be tweaked in different angles and positions and unclipping the pass side fat harness so it can be pulled foward a little to take pull off one of the clipped on wire harness connections. Positively cannot use the insulation piece that sits on top of the valley under the OE intake . Will be happy to answer anyone questions.
03-12-2021, 06:33 PM | #2 |
Oldman w/a teenager brain
Drives: 2022 ZL1 A10 Join Date: Mar 2021
Not being facitious, but why? I'm still learning.
03-12-2021, 06:36 PM | #3 |
03-12-2021, 06:43 PM | #4 |
Drives: 2017 SS 1LE Join Date: Mar 2017
I do mine on Saturday and paid Pray Performance to optimize it all in a few weeks (backlog of work).
03-12-2021, 06:48 PM | #5 |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
You might want to torque them down to the correct torque values.
1. First pass 44 lbs 2. Second pass 89 lbs Even if your saying 75 to In./Lbs. (Nm) that’s 102 lbs.
LT4 1.7 Supercharger snout ported & Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver Last edited by BlackbeastSS2; 03-12-2021 at 07:22 PM. |
03-12-2021, 06:52 PM | #6 |
03-12-2021, 06:58 PM | #7 |
The 75 in lbs spec comes from the aftermarket intake spec sheet along with the torque sequence. Just not liking the feel of torqueing the intake that tight. I did 25, 40, 75 , than 75 again after driving and intake was fully warmed. The aluminum on aluminum throttle body torque feel is much better and what I am used to feeling.
03-12-2021, 07:01 PM | #8 |
03-12-2021, 07:09 PM | #9 | |
Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
ZL1 Coupe, PDR, Exposed carbon fiber hood insert, My Link with Nav, M6 6 speed and Silver Ice Metallic. Mods done: ceramic window tint, GM Accessories Camaro floor mats and Roto-Fab CAI.
03-13-2021, 12:35 AM | #10 |
Drives: Chevrolet Camaro Join Date: Jan 2021
Yeah I’m definitely interested in what is causing the cel. Got my intake ready to go on.
03-13-2021, 12:39 AM | #11 |
Drives: like an old lady Join Date: Jun 2012
low idle and codes? vacuum leak?
2016+ camaro: everyone’s first car
03-13-2021, 06:49 AM | #12 |
Thank you for the suggestion. I opened up my OE air box by smoothing out the upper and lower halfs from all the fins and opened the front of the air box so it draws cool air under and in addition to the OE inlet. The additional air inlet source is sealed like the OE inlet so it has no chance of drawing under hood heat air. I also removed the snow block rubber and trimmed the lower flange on the left headlight so now I can look thru the grille and see right into the air box. My air box is cold to touch as is the throttle body (Same as ambient air temp) on a cool day after a drive proving it draws outside ambient air only. Not so sure the Roto Fab totally isolates under hood hot air from being inhaled and so far no cost.
03-13-2021, 06:53 AM | #13 |
03-13-2021, 09:57 AM | #14 |
Drives: Camaro SS 1LE Join Date: Aug 2018
So much cheaper than msd— very tempting!
