Old 08-21-2018, 09:35 AM   #1
Iroc-z86
Drives: 86' Iroc-z 14' Camaro SS 98' Jimmy
One-Piece Aluminum Driveshaft install
Hi!
I purchased a DSS aluminum driveshaft along with 3.91 gears, new axles and poly bushings for my 2014 Camaro SS. While installing the driveshaft, instructions say to measure the distance between the joint and the shaft. The gap should be between 3 1/4in and 3 3/4 in. I measured mine and its 3 1/8in. Has anyone else had this issue? When installing, the rear went in a little tough with zero forward or backward play.
Thanks!
2014 Camaro SS - Summit White W/ Inferno Orange stripes and interior package. Borla Atak catback, RotoFab CAI, Truetrac diff, 3.90 gears, DSS driveshaft and axles, LPW diff cover.
1986 Camaro IROC-Z - 305 TPI, cammed, GMMG exhaust, t56 6Spd swap, custom headlights with halos
Iroc-z86 is offline   Reply With Quote
Old 09-07-2018, 11:14 AM   #2
Iroc-z86
Update: Installed the ds as it was. spoke with DSS about it they said there could or could not be issues with running it with that little clearance. The pinion seal is now leaking, but it could be the cheap seal that was included with the rebuild kit. Going to take it to a transmission shop and ask their opinion and get the seal replaced with a GM part.
Anyone else have a one-piece DSS driveshaft?
Old 09-07-2018, 02:10 PM   #3
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
I have one and got from a Forum member in Canada, I just installed it and been driving with for 2-3 years without issue, didn't measure anything just installed it.
I however did ask for a set of instructions and didn't really get much.
Orange Krush II
Old 01-29-2021, 01:00 PM   #4
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Did you notice the car being any quicker from idle ? Any NVH ? Thanks
camguynj is offline   Reply With Quote
Old 01-29-2021, 03:59 PM   #5
gsxrturbo
Drives: 2010 ss
dss has some history with there driveshafts being to long,not the first time i have seen this.Ask me i know, those guys are a pain in the but to deal with
gsxrturbo is offline   Reply With Quote
Old 02-02-2021, 02:41 PM   #6
xdamxincx
Banned
Drives: zl1 blk
i agree .. dss pita to deal with .. wont give measurements of driveshaft lengths.. all top secret and stuff....
xdamxincx is offline   Reply With Quote
Old 02-03-2021, 01:44 AM   #7
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
DS Accel an NVH
The car seemed more responsive off idle not necessarily quicker, and no noise that I can speak of. Hope that helps.
Orange Krush II
