09-13-2018, 09:18 AM | #1 |
Drives: 2012 45th Anniversary Edition Join Date: Aug 2012
Key fob update
ordered the new (empty) fob on Amazon - had the switchblade key cut at dealership (was actually cheaper than locksmith, imagine that), had to annihilate my old fob in order to transfer the electronics, but in the transfer, the replacement one (with the same guts from the old one) does not work - any suggestions? Key works, but i get a 'Clear theft deterrent system' on my dic..... when trying to program..
09-13-2018, 09:20 AM | #2 |
forgot picture.....................
09-13-2018, 01:02 PM | #3 |
Drives: 2SS/RS Join Date: Sep 2008
Why order a empty fob with no electronics when you can order one with the electronics for $12?
Anyway, have you tried using your spare to start the car? Using the spare original fob should clear the message and allow you to program. If that doesn't work, you may have ruined the electronics when switching them over and will have to get another key. Here is that I bought when I needed one. Had a dealer cut it and programmed it while sitting in the parking lot. https://www.ebay.com/itm/Replacement...53.m1438.l2649 |
09-13-2018, 03:33 PM | #4 |
[QUOTE=Mr_Draco;10310151]Why order a empty fob with no electronics when you can order one with the electronics for $12?
Anyway, have you tried using your spare to start the car? Using the spare original fob should clear the message and allow you to program. If that doesn't work, you may have ruined the electronics when switching them over and will have to get another key. Here is that I bought when I needed one. Had a dealer cut it and programmed it while sitting in the parking lot. https://www.ebay.com/itm/Replacement...53.m1438.l2649[/QUOT I thought the one i got had electronics.. it basically came empty with a blank flip out. didnt realize it until i had one in each hand and noticed how much lighter it was. the one you got HAS the electronics, correct? what about the key part? |
09-13-2018, 05:06 PM | #5 |
Drives: 2011 2SS/RS M6 Join Date: Oct 2015
My brother did the same thing as you with his Yukon. Ordered an empty case for his because the ring broke off. After putting in his electronics the rear hatch would open anytime something bumped the fob or you ran your finger over the button. It's possible that the new case isn't quite right and is causing an issue with the circuits.
_edit_ If it was just an empty case you shouldn't have to program the key again. |
09-14-2018, 09:12 AM | #6 | |
09-14-2018, 10:00 AM | #7 | |
Your dealership will have pins, as will a locksmith. |
09-14-2018, 10:12 AM | #8 |
Banned
Drives: Camaro Join Date: Aug 2018
It’s $45 or $55, forget which, for a brand new fob with key cut at a gm dealer. You made this way to hard.
09-14-2018, 05:50 PM | #9 |
my dealership quoted me well over $100 - as stated in earlier posts, I thought the one I bought had the electronics, did not realize it until I discovered the weight difference after getting the key cut. So, i took my original apart, and attempted to swap the insides into the empty one, that didnt work. NOW, I found one on Ebay, which has the electronics, and when I get that one, I will exchange the key. not hard to follow.
09-18-2018, 12:29 AM | #10 |
Drives: Chevys Join Date: Mar 2013
I ordered one for $20 and cut the key for $10 and used my current one to program it
09-18-2018, 10:10 AM | #11 | |
Banned
09-18-2018, 01:44 PM | #12 |
just didnt feel like calling 17 dealers, when the closest one is less than 10 miles away. My fault for not reading the description on Amazon - all good now, got one with electronics. No just swap the key. done.
