Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Members Area > Ask the Camaro Team
Old 05-06-2018, 03:15 PM   #1
DBHWT
DBHWT's Avatar
Drives: 2013 SS 1LE
Run flat tires
Has GM ever considered run flat tires on the Camaro ?
DBHWT is offline   Reply With Quote
Old 05-06-2018, 03:38 PM   #2
ChevyRules
Drives: 2021 Tesla Model 3 LR
The SS, V6 1LE, and RS models come with run flats. Non-RS, SS 1LE, ZL1, ZL1 1LE do not.
ChevyRules is offline   Reply With Quote
Old 05-07-2018, 09:33 PM   #3
Commando16SS
Drives: n/a
How do those cars, specifically the ZL1's, offer a solution to fix a flat while driving then? From what I understood, any car has to be able to offer either a spare, tire inflater/patch kit, or some sort of run on flat tires unless I am mistaken. Thought most performance car OEM's went with run on flats to save the weight of the kit and the spare plus more equal weight distribution.
Commando16SS is offline   Reply With Quote
Old 05-07-2018, 10:41 PM   #4
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
99.99% sure they use inflator kits.
Better weight distribution is probably more of a turn lemons into lemonade kinda thing than an actual benefit. Your performance pretty much always going to be better off with less weight period than adding a bit more to give it better balance.
Run flat tires can provide 'good' performance, but rarely (if ever) 'great' performance. So the higher the performance target, the harder it is to make a runflat that will meet it. And on something like the ZL1 1LE it'd be impossible.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 05-10-2018, 05:08 PM   #5
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
SS 1LE's come with an inflator kit in the trunk, I think it has a sealant as well.
'18 1SS 1LE Black, PDR
Boost Creep is offline   Reply With Quote
Old 05-10-2018, 10:06 PM   #6
Boost or bust
Drives: 2018 ZL1 M6
‘18 ZL1 here. Inflator kit with sealant...super lame.
Boost or bust is offline   Reply With Quote
Old 05-11-2018, 03:29 AM   #7
Msokeefe
Drives: 2018 1SS
I would imagine the inflator kits make a mess of your rims wen you use it?
Msokeefe is offline   Reply With Quote
Old 05-11-2018, 09:32 AM   #8
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
I'd be more concerned for the TPMS sensors. Wheels can be cleaned . . .
Norm
'08 GT coupe 5M (the occasional track toy)
'19 WRX 6M (the family sedan . . . seriously)
Norm Peterson is offline   Reply With Quote
Old 05-11-2018, 11:51 AM   #9
Boost Creep
Drives: '18 1SS 1LE
I carry a tire plug kit, so unless there is a huge gapping hole in the side wall, I will pull the nail/screw plug the tire and fill it until I can throw a patch on it.
Old 05-11-2018, 12:52 PM   #10
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Slime kits are safe for the sensors, it says it on every can or compressor system they sell.
Glen e is offline   Reply With Quote
Old 05-18-2018, 06:07 PM   #11
Joey Soul
The Mechanic
Joey Soul's Avatar
Drives: 1SS M
ive always carried a plug kit but from working at porsche for a while, 911s come with sealant and everytime someone used it the tire never sealed and the sensor always failed.
Joey Soul is offline   Reply With Quote
Old 01-20-2019, 04:00 PM   #12
Fatty1707
Drives: 2019 ZL1 A10
I just made a video on pluging my ZL1 rear tire with 25 miles on it. It was a challenge and entertaining! And of course the tires are over inflated from the dealer.
https://youtu.be/hqKSasPVGB0
Fatty1707 is offline   Reply With Quote
Old 01-20-2019, 05:56 PM   #13
Boost Creep
Drives: '18 1SS 1LE
Tire plugged in sidewall, should be replaced, the hole is outside the acceptable patch/plug area of the tire tread.
Also, reamer identical to the reamer shown, is used by being pushed in and out several times, and the rope plug used would be the thinner black plug rather than the thick brown plug.
When taking delivery on mine, right before I left the lot I spotted a screw in the tread of the right rear tire, had them swap out wheel/tire with another unit.
Old 01-20-2019, 10:21 PM   #14
karmatourer
STD free
karmatourer's Avatar
Drives: 2018 Bright Yellow LGX M6 RS NPP
The window sticker on my '18 V-6 RS says," 20" machined aluminum premium gray wheels w/run-flat tires,STD equipment tire sealant & inflator kit deleted".
karmatourer is offline   Reply With Quote
