Old 11-15-2014, 05:48 PM   #1
etmx183
etmx183's Avatar
Drives: 2012 Camaro 2LT RS
Getting close to 11:xx
12.03 today just a little more and I'll have it.
etmx183 is offline   Reply With Quote
Old 11-15-2014, 06:08 PM   #2
Jason@JacFab
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
You're SOOO CLOSE!!! What's your next plan of attack? Weight reduction?
Jason@JacFab is offline   Reply With Quote
Old 11-15-2014, 06:12 PM   #3
etmx183
etmx183's Avatar
Was having issues with the nitrous solenoid anything over 900 psi it would not open. I'm going to try my other set out next weekend. I usually run 975 - 1000 PSI and I was rich after the 1/8 mile. So I think if I get the bottle pressure up it will take care of what I need. By the end of the run my bottle pressure was in the 750 - 800 range.
Old 11-15-2014, 06:17 PM   #4
etmx183
etmx183's Avatar
I'm working on the driver mod weight reduction, but want to leave the car OEM. That way no one can say it is gutted not a true street car. Leather, heated seats, power everything all there and all working.
Old 11-15-2014, 06:30 PM   #5
Jason@JacFab
I feel ya, I'm working on driver mod weight reduction myself... It's tough to drop 100lbs.
I'm picking up what you're laying down, I would also prefer to leave the car intact without ripping out whatever you can to get a better time.
Well, I hope your solenoid issues fix your "problems" and vault you into the 11's.
Old 11-16-2014, 06:51 AM   #6
etmx183
etmx183's Avatar
Old 11-16-2014, 07:29 AM   #7
JantzenOKC
JantzenOKC's Avatar
Drives: '13 2LT/RS Twin Turbo
Nice. That thing is movin!
JantzenOKC is offline   Reply With Quote
Old 11-16-2014, 07:58 AM   #8
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr
After watching the video, it sounds like you still have a traction issue and fix that u have 11's
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS.
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47**
Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver
Daily Driver 2021 BMW M340i Xdrive
IneedAZ is offline   Reply With Quote
Old 11-16-2014, 09:43 AM   #9
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
Hex vents to keep the radiator core cooler?
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 11-16-2014, 10:01 AM   #10
garvyf22
Tonkaracing
Drives: 2013 2LS RED CAMARO
Every ran a zl1 yet???
garvyf22 is offline   Reply With Quote
Old 11-16-2014, 10:21 AM   #11
etmx183
etmx183's Avatar
I do tow the car to the track and I have two large fans I keep on the engine and trans between runs to keep temps down. There are few ZL1 s in our local club and I have run with them. The one runs upper 12:0x and the other 11:8x. The one in the 11s I kill off the line and my reaction time keep us neck and neck on the big end. Thanks for all the kind words and encouragement.
Old 11-16-2014, 10:26 AM   #12
MagnumForceGB
You will be surprised at how much heat builds up during a run, especially the oil temps since ours are a calculated sensor, not a real sensor. Do you see what your timing advance is during a run? If you are running rich it usually means you might be running too little timing and causing some power up top to be left on the table.
Your DA during that run kills me, it is -1189 right now here but it is snowing on the ground. I need to go to a low altitude track one time to break some records.
Old 11-16-2014, 11:24 AM   #13
SrtWtF
SrtWtF's Avatar
Drives: Nsrt & Camaro SS
Motivation
SrtWtF is offline   Reply With Quote
Old 11-16-2014, 01:21 PM   #14
KMPrenger
KMPrenger's Avatar
Congrats! So close!
By the way, you guys need to post up your new times to Gretchen's thread:
http://www.camaro5.com/forums/showthread.php?t=115679
The thread is about power, but also has times...need to get them on there.
