Old 10-16-2018, 08:35 PM   #1
rebelyell22
rebelyell22's Avatar
Drives: 2011 SIM 2SS/RS LS3
Brake Issue
Brakes are spongy and will go to the floor with a little pressure. Firms up if I pump the pedal with the car off. Bad master cyl?
2011 2SS/RS built 8/24/10
rebelyell22 is offline   Reply With Quote
Old 10-16-2018, 08:55 PM   #2
Leo72793
Drives: 2011 2SS/RS
check fluid. if you recently did a fluid change, then it has air in them.
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels
•Vararam Ram Air Intake
•Speed Engineering Longtube Headers w/ Magnaflow HF Cats
•Bo White PnP Stage 2 TB
•GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression
•Xpipe w/ Res Delete and NPP Exhaust
•Tuned By Anonymous Calibrations
•Gen5DIY Mylink Conversion W/ Backup Cam
•Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle
•Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp
Leo72793 is offline   Reply With Quote
Old 10-16-2018, 09:09 PM   #3
rebelyell22
Nope. It’s rock solid with the car off.
Old 10-16-2018, 10:16 PM   #4
rebelyell22
No fluid in the booster, no leaks at the calipers, and the fluid level is good...
Old 10-17-2018, 01:56 PM   #5
HOU_TX_SS
Drives: Camaro SS
I'm in the same boat. I've tried everything. I'm leaning more towards vacuum in my case though but still haven't sorted them out.
Fully Built 416ci / Procharger F1X / Century Built 4L80 / ZL1 Differential / Alky Control Meth /Circle D Triple Disk / ID1300s / Fore Innovations Return / Kooks Full Exhaust / Holley HiRam / e85 / 15in Conversion on Forgestar Beadlocks / Tuner: Pat G
HOU_TX_SS is offline   Reply With Quote
Old 10-17-2018, 03:53 PM   #6
rebelyell22
I'm about done with this thing. It's fun, but damn it's a pain in the ass
Old 10-18-2018, 05:13 PM   #7
1Coopgt
1Coopgt's Avatar
Drives: All Black 2012 1LS
This doesn't tell you it you have a problem with your brakes . Your pedal should firm up when you don't have the engine running . If you pedal is going to the floor when the engine is running you may have air in the lines , bleed them or you could have a brake booster issue.
When you have the engine running and you pump the brakes does the pedal firm up ?
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
1Coopgt is offline   Reply With Quote
