Jason 98 TA
Old 07-02-2011, 08:18 PM   #1
JB @ C and L Machine
Drives: Ordered 2011
Smallest Maggie pulley on stock bottom end?
What's would safe pulley size? I am running a 3.6 now with headers , cam and a boost a pump plus a tune.
JB @ C and L Machine is offline   Reply With Quote
Old 07-02-2011, 08:31 PM   #2
Turbo99
Turbo99's Avatar
Drives: 08' F250 Diesel & 10' Camaro 2SS
I am running a 3.4 but didn't get much power over the 3.6. I gained 20-25hp
Contact me for questions: coopwfo@gmail.com I cant send/receive PMs.
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 10psi 10.82@130mph
TVS2300 ,Hendrix Street Slayer Twin Carbon Clutch, Dana 60 3.73, DSS 1400HP Axles,JRe cam & LaMotta Performance tuned,LPE Fuel, AI Super Chiller,MT ET Streets
Turbo99 is offline   Reply With Quote
Old 07-03-2011, 01:16 AM   #3
boostedyards86
boostedyards86's Avatar
Drives: Cummins 3500
open up air flow but dont go over 12psi or things will get dicey...
85 Buick TType - 5.3l GT4202r 10.86 at 126
boostedyards86 is offline   Reply With Quote
Old 07-03-2011, 07:52 AM   #4
Hendrix-Engineering
Drives: First 9 inch-12 bolt IRS Camaro
I agree,intake flow and tb is key to extracting the power out of any positive displacement blower.We will have a special intake in 60 days but we have custom tbs now...Let me know if i can help you.On the pulley i would overdrive the rear and put the bigger pulley back on the front for belt wrap.Let me know if i can help you out with that as well.
Hendrix-Engineering is offline   Reply With Quote
Old 07-03-2011, 09:31 AM   #5
Turbo99
Turbo99's Avatar
So you need to port the throttle body? Like I said I didn't gain alot through a pulley change.
Old 07-03-2011, 09:38 AM   #6
Supercharged SS
Drives: 2010 Camaro
+1! If you are on the 6 rib anything lower than a 3.4 will slip. I was on a 3.2 with the stock bottom but had the 8 rib. If you want some more boost go with the OD rear like these guys suggested. Then you can run a 3.6 and have great belt wrap.
Old 07-03-2011, 10:51 AM   #7
SC2150
We use the 3.4 with the Gator Grip antislip all the time with no slip issues (have no complaints on the 3.2 version either...see the super chiller thread). The tune is key as well but we have hundreds of the Gator Grip anti slips in use without slippage.
Old 07-03-2011, 11:14 AM   #8
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
There are Several things to consider.
The LS9 injectors that come with the Magnacharger run out below 3.6
Fuel Pump Runs out below 3.6 even with MSD fuel pump voltage booster.
Camshaft affects what you can run for a pulley.
Limitations have more to do with OCTANE and Fuel supply Than the Boost Number.
LS3 and L99 can run different pulley, usually 1 size smaller on the L99 due to the lower compression.
Below a 3.6 Belt slippage starts to be a Problem, which our super tensioner addresses.
Any Questions Feel free to discuss.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 07-03-2011, 11:35 AM   #9
Hendrix-Engineering
THat would help a tiny bit,we have a billit 102 which will provide a sizeable gain and lower your iats
Old 07-03-2011, 11:38 AM   #10
Hendrix-Engineering
Thats a pretty good gain to the tire and is about the norm
Old 07-03-2011, 12:38 PM   #11
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
how much power are you talking to the wheels and how much reduction in IAT's? whipple told me there really is not much gain until you get a bigger motor.
94guy is offline   Reply With Quote
Old 07-03-2011, 01:53 PM   #12
Hendrix-Engineering
Thats not what our results show,we picked up 25 rwhp and 4 mph in the 1/8th switching from a 78mm tb to our 90mm tb on a 346 ci motor with a lil 112. I have headers and a 2300 on a stock ls3 with the stock airbox going through a 9 inch on 22s .Whith our 102 tb it makes 575 rwhp......We are making over 850 rwhp with our 408 gto with our 102 and it still isnt enuff tb,we are doing a special snout with twin 90s and should have results in 60 days
Old 07-03-2011, 01:56 PM   #13
94guy
i'm talking from a 90mm to the 102.
Old 07-03-2011, 02:03 PM   #14
Hendrix-Engineering
We have a customer with a 1900 on a camaro that will be changing soon ill get the info.Tb and air intake is the most important piece of the puzzle when building a pd package.
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3498 08-04-2018 05:18 PM
DIY : Install underdrive pulley on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 34 09-30-2013 08:25 PM
805 RWHP 699 RWTQ From a Stock bottom end LS1 Camaro Clint@A.I.R. General Automotive + Other Cars Discussion 8 07-03-2011 07:29 PM
TVS2300 set-up question(s) TinyToasta Forced Induction - V8 51 03-14-2011 01:40 PM
Maggie experts...5 lbs boost on a 3.6 pulley? Luvpilot Forced Induction - V8 2 06-04-2010 07:16 AM
