07-27-2017, 10:12 PM | #1 |
Drives: 2015 1LE Join Date: Oct 2015
1LE cradle bushings
Does a 1LE have different cradle bushings than a regular SS?
07-28-2017, 04:14 AM | #2 |
Yes, the are much firmer but you can get stiffer ones. When I had the 1LE track pack installed on my car it really help cut down on wheel hop.
07-28-2017, 08:23 AM | #3 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Get solids from one of the vendors you won't be disappointed!!
Orange Krush II
07-28-2017, 08:57 AM | #4 |
I have a 1LE and wanted to upgrade the subframe bushings and was trying to decide on poly or solid. Sounds like most people recommend solid. Even though these dont transmit much NVH I was wondering how it will get with aftermarket trailing arms with poly bushings.
07-28-2017, 10:44 AM | #5 |
Drives: Race Car Join Date: Sep 2009
I would get Solids!
However, remember if you replace your Cradle or Diff Bushings, there is no way to go back without buying a New Cradle |
07-28-2017, 11:02 AM | #6 |
You shouldn't see any NVH till you do diff Bushings and only minor on arms.
Orange Krush II
07-28-2017, 11:19 AM | #7 |
Solid it is!
