Old 09-23-2021, 11:57 PM   #1
EJSS
Drives: 2010 Camaro SS L99
Changed Spark Plugs now misfire on all cylinders
Im left sort of speechless on this one...
I changed all of my spark plugs last night on my L99, went with the same exact plugs that were already in, the GM 41-110 Iridiums. Same spark plugs, same gap. Misfires on all cylinders, knock retard going crazy... I can hear an audible knocking/tapping sound on my way home from work.
So tonight, I just pulled all 8 of the new plugs out and replaced the old plugs back in. No more misfires, everything is back to normal. WTF? How does the car know the difference between the new ones and old ones?? Why does it like the old ones more? Same exact plugs with the SAME DAMN GAP. C'mon man!
EJSS is offline   Reply With Quote
Old 09-24-2021, 05:00 AM   #2
102SS
waiting at the tree
102SS's Avatar
Drives: SIM 2010 2SS/RS A6
Maybe your new plugs were dropped or handled roughly before you bought them.
I put Denso Iridium's in mine and everything is fine.
2010 2SS/RS A6 ZL1 Rims
60ft 2.03 13.08 at 107.82 (4/28)
2009 Pontiac G8 3.6L the DD
102SS is offline   Reply With Quote
Old 09-24-2021, 06:03 AM   #3
Y88 TA
Y88 TA's Avatar
Drives: 2010 RJT 2SS 6 Manual, 1978 Y88 TA
Where did you buy your new plugs from? Could be cheap knock offs from ebay or amazon.
Y88 TA is offline   Reply With Quote
Old 09-24-2021, 07:11 AM   #4
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
Just because a part is new doesn’t mean it’s good
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 09-24-2021, 07:33 AM   #5
EJSS
Nevermind problem came back lol. Spoke too soon
Old 09-24-2021, 07:34 AM   #6
Aqua Blue RS/SS
Aqua Blue RS/SS's Avatar
Drives: ABM 2399
This!!! There’s a flood of Chinese knock offs on the market, they can be a little hard to spot from the real ones.
”Blue”ABM #2399, 2010 2SS/RS: GM GFX, GM Heritage, GM dovetail, Silver Ice Rally stripes.
Aqua Blue RS/SS is offline   Reply With Quote
Old 09-24-2021, 07:37 AM   #7
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2010 Camaro 2SS A6
Now that you have replicated the problem with the old plugs, it's time to consider whether the wires are OK. It's not hard to damage them if you take them off roughly.
Rock-It Man is offline   Reply With Quote
Old 09-24-2021, 09:05 AM   #8
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
^^^ this, I have seen where the connectors inside the boot come apart and not make a good connection anymore and cause problems. Check the plug wires.
TSP STAGE 3 CAM,231/246 @112 LSA 614/641 LIFT, CIRCLE D 5C-4200-4500 CONVERTER,LOD INTAKE.CORSA EXHAUST. DSS 1 PC DS. PEGASUS SOLID CRADLE MOUNTS. 486RWTQ/475RWHP.LOTS MORE.
Old 09-24-2021, 01:33 PM   #9
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
If it has factory wires replace them. Mine where original last year and many where dry rotted. By removing them you might of compromised there integrity of them and now they are giving you problems.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 09-25-2021, 12:08 AM   #10
EJSS
Thanks everyone, I will be replacing the wires ASAP and I'll do an update once it's done.
Old 09-25-2021, 01:38 AM   #11
AlanRubin
Drives: 2010 LS
As the plugs age, and the gaps widen with age, the ECU adjusts. When you replace
the plugs, the timing will be off slightly, the ECU needs reset. The "learning"
is gradual as they age, then you jump down to a gap that's original, which will be
smaller than the old plugs. IT happens...
Also, yeah, the connector in the boots can pull out of the crimp... Just had that
happen on my Mustang, but only two of them.
AlanRubin is offline   Reply With Quote
Old 09-25-2021, 03:01 AM   #12
FlashCamaroSS
FlashCamaroSS's Avatar
Check the flow of charge with electric tester. might have a bad wire or 2.
FlashCamaroSS is offline   Reply With Quote
Old 09-27-2021, 11:46 AM   #13
HyperV117
HyperV117's Avatar
Drives: 2010 Camaro 1SS
I had this happen once. Turns out I didn't push the plug cables all the way in.
HyperV117 is offline   Reply With Quote
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
