Old 08-20-2013, 09:03 PM   #1
Tony Stark
Drives: Camaro
If use paddle shifters can you switch to auto drive without stopping?
Hey guys,
I have never owned a paddle shift car (referring to an automatic Camaro)
from research I know you can drive the car in manual mode without using the paddle shifters which is sport mode...
but if you were to use a paddle to pop into a couple gears on the highway but get tired of it. can you simply paddle over to D or S?
Tony Stark is offline   Reply With Quote
Old 08-20-2013, 09:07 PM   #2
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Of course you can....chev would sell none of this if you had to stop and warranty costs would kill them....
Glen e is offline   Reply With Quote
Old 08-20-2013, 09:40 PM   #3
Tbanks
The Stangs kryptonite
Tbanks's Avatar
Drives: 2010 1LT CGM Camaro
once you are in S and change gears using the paddle shifters, hold the right shifter for like 3 seconds and you will be put back into S mode
TBANKS
Tbanks is offline   Reply With Quote
Old 08-20-2013, 09:43 PM   #4
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '20 Corvette Stingray
or you can just bump the shifter from S to D or from D to S anytime on the fly.......I've done it many times.
Old 08-20-2013, 09:47 PM   #5
oldfriend
Drives: Fiat 500 E
And have you broken anything yet ?
Old 08-20-2013, 09:48 PM   #6
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Drives: 2011 2LT/RS Camaro IOM
That is what I do, never had any problems.
kjkjr27 is offline   Reply With Quote
Old 08-20-2013, 09:49 PM   #7
SIN R G
Drives: 2008 VW R32, 2011 Synergy Green 2SS
Yup, exactly what Tbanks said..
SIN R G is offline   Reply With Quote
Old 08-20-2013, 09:53 PM   #8
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
I paddle shift my car all the time..u cannot gear down if you speed or rpms are to high..nothing will break
rontammy0 is offline   Reply With Quote
Old 08-20-2013, 10:00 PM   #9
crateish
crateish's Avatar
Drives: 45th Anniversary 2LT/RS Coupe
If you are using the paddles, move the stick into D. Then right back into S, if you want the automatic Sport mode, sans paddles.
Easy peasy.
crateish is offline   Reply With Quote
Old 08-20-2013, 10:10 PM   #10
Alot9439
Alot9439's Avatar
Drives: 2SS RS
Its not like your moving from D to R your pretty much in the same gear.
Alot9439 is offline   Reply With Quote
Old 08-20-2013, 10:15 PM   #11
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
What would break? It's hardly any different than holding in the paddle to return to sport mode. And immediately dumping it into 5th or 6th gear.
Not like it is two different trannys with two sets of gears. All sport mode does is give a little firmer shifts and holds the revs a tad higher.
Quite tame and lame compared to getting your tranny tuned so that even D is way better then the stock sport mode.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 08-21-2013, 05:43 AM   #12
007s 'Vert
Formerly Lil'BlueCoupe
007s 'Vert's Avatar
Drives: '13 2LT/RS Vert, Summit White
I use my paddle shifters all the time, sometimes when I want to pass and not want to rely on the trans automatically kicking down I just use my paddles and kick it down to the gear I want and away I go.....just love doing that.
I rarely need to even put it into S mode, but sometimes when I am on the back twisty roads and am feeling like I wanna have some fun, I will for sure put it in S mode and have at it, it is a blast to drive that way especially once you learn the ways of the paddle shifter lag timing.
007s 'Vert is offline   Reply With Quote
Old 08-21-2013, 06:27 AM   #13
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
^^^ This ^^^
This is a smart car. I won't let you do anything that might tear up the tranny. Go ahead and experiment with it... get to know your Camaro!
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
PalmerGA is offline   Reply With Quote
Old 08-21-2013, 09:03 AM   #14
classicrockr
Pills are for Pansies
classicrockr's Avatar
Drives: 2023 2SS Red Hot Vert Camaro
Originally Posted by PalmerGA View Post
^^^ This ^^^
Experiment is exactly what I need to do. I've just been too chicken to do it and if the wife's in the car, I sure as heck can't do it - she'd freak out & think something was wrong with the tranny. I need to find an empty road somewhere...
classicrockr is offline   Reply With Quote
