Old 01-20-2019, 08:07 PM   #1
beersngars
Drives: 2012 ZL1
Line lock experiance
I picked up some Hawk ceramic pads to help with the damn dust. Also bought a few bottles of Motul dot 4 to flush out the system and thought about adding a line lock while I'm at it. I don't drag race or just do smoke shows but thought it would be nice to add a little heat if I want to get a little aggressive on the right road. So far I'm liking the Hurst direct fit kit rather than fabricating the mount and line. Anyone have feed back good or otherwise?
beersngars is offline   Reply With Quote
Old 01-20-2019, 09:26 PM   #2
d454brisson
Drives: 2014 ZL1
I have the hurst kit specific for camaro, (567-1518) Super easy install, I mounted a single lighted Aircraft toggle near the Dome light and Homelink.
This way you open the toggle, pump the brakes and flip the switch to engage.
When ready to disengage during burn out just flip the lid closed (big target for hand) and roll out.
d454brisson is offline   Reply With Quote
Old 01-20-2019, 09:43 PM   #3
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
I run the SJM kit. It fits like a glove.
sjmmanufacturing dot com
We wired it into the horn button... There is a switch on the center console, that powered the system. The horn then actuates the system. Step on the brakes, push the horn button, then release the brakes.... I start my burnout and then release the horn button when I'm ready to roll out....
Old 01-21-2019, 01:49 PM   #4
@ReaperZL1
Drives: 2013 camaro zl1 aka the Reaper
has anyone tried both the sjm and the hurst kit and can give first hand pros and cons about each kit? looking at ordering one myself
@ReaperZL1 is offline   Reply With Quote
Old 01-21-2019, 06:55 PM   #5
beersngars
Drives: 2012 ZL1
This is the first time I've heard of the SJM kit. I like to buy the best the first time. Will have to do some DD.
Old 01-21-2019, 07:12 PM   #6
@ReaperZL1
I know one of the youtubers I watch has one on his zl1 and he only had a problem with it once if I remember correctly. other than that it works great. he does have an auto though
