Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Road Course/Track and Autocross
Old 02-18-2011, 07:53 AM   #1
guyjusthere
guyjusthere's Avatar
Drives: 2016 2SS Camaro
Exclamation First race this weekend! I'm FREAKING OUT!
Closed track in homestead, FL...
This is a begginer race with passing allowed
I need tips on how to race this damn car?!
* What do I bring?
* What should I do before race?
(I'm in beginner series so I don't really need racing tips, yett)
2010 SS black - Intake/Exhaust/Nitrous (wont be connected :/)
M6
Last edited by guyjusthere; 02-18-2011 at 08:42 AM. Reason: forgot to add tranny type... DUH
guyjusthere is offline   Reply With Quote
Old 02-18-2011, 08:04 AM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
M6 or auto? If she's an auto leave it in drive and just hang on. If she's standard then I'd say shift around 4500 or 5000. Do a burn out before hand to heat up the tires so they'll stick better. Leave traction control and all that on for the race c
Click to view my build thread
Old 02-18-2011, 08:17 AM   #3
guyjusthere
M6... Sounds good. Any other tips for setting up car? Things to bring?
Old 02-18-2011, 08:29 AM   #4
Beescuz
Beescuz's Avatar
Drives: 2021 ZL1 1LE
Get some good rubber!
If have street radials drop the air pressure and good luck!
Beescuz is offline   Reply With Quote
Old 02-18-2011, 08:33 AM   #5
BlaSSt Off
BlaSSt Off's Avatar
Drives: 2SS/RS
If you are bracket racing, use launch control so you are consistant. Just hit the traction control button twice so it is in "competition mode", if your on street tires, GO AROUND THE WATER BOX, you dont have to do a massive burnout on street tires, just clean them off. Prestage, push the clutch in, when your both staged, stomp the gas peddel to the floor and the RPMs will level out at 4k and when the last yellow lights up, DUMP the clutch and GO!!!! If you wait for the green light you lost.
BlaSSt Off is offline   Reply With Quote
Old 02-18-2011, 08:35 AM   #6
Murph0408
Murph0408's Avatar
Drives: 2LT Black '10 Camaro, 2000 Durango
here's a tip, don't crash
Murph0408 is offline   Reply With Quote
Old 02-18-2011, 08:42 AM   #7
guyjusthere
This is not a drag strip it is a closed tack
Old 02-18-2011, 08:54 AM   #8
ljstella
CAMARO FAN
Drives: 2007 Subaru Impreza
You're planning on racing your almost entirely stock car on a closed track?
Don't do anything with power, get tires, new brakes pads and rotors and brake lines, and brake fluid. You might want to consider doing a typical fluid change if you're coming up close on an interval.
ljstella is offline   Reply With Quote
Old 02-18-2011, 08:58 AM   #9
The Stig
The Stig's Avatar
Didnt know this was a closed track. To clarify you're talking about autocross correct? If so after you finish all your passes change as many as possible if not all the oils in your car. Specifically clutch, brakes, and engine oil (if possible)
Old 02-18-2011, 10:51 AM   #10
guyjusthere
autocross... Beginner race - so it shouldn't be too bad on my car. I Will be changing tires and brake fluid. I don't see what is so crazy to race our car stock, it's not too bad
Old 02-18-2011, 11:22 AM   #11
CyberPredator
50 Shades of Prey
Drives: TT/SS
Make sure you have a decent amount of camber in the front of the car, because these cars stock roll over the sidewall fast. Also put it in competitive mode, because with everything on it understeers even worst. Have a good time and enjoy yourself.
Futral Motorsports built and tuned
CyberPredator is offline   Reply With Quote
Old 02-18-2011, 11:22 AM   #12
RatRacer
RatRacer's Avatar
Drives: 11 Synergy Green LS 15 Colorado Z71
Have you, by chance, put in a rear sway bar? That would be the first thing I'd do if I was thinking on doing this.
RatRacer is offline   Reply With Quote
Old 02-18-2011, 11:30 AM   #13
denny2188
denny2188's Avatar
Drives: 2011 IBM Camaro 2LT
Racing your 2010 SS on an Oval Track????????? No Thank You!!!!!!!
denny2188 is offline   Reply With Quote
Old 02-18-2011, 11:36 AM   #14
CyberPredator
50 Shades of Prey
Drives: TT/SS
I've got some pictures of me on a 1.9 mile road course in mine. It's a lot of fun but these cars with stock suspension go through front tires pretty quick especially on rough tracks. We did 3 20 minute sessions and of the 15 cars there I only got beat by a GT3 cup car and a viper.
https://picasaweb.google.com/Talisman013. It's the two that say Grand Bayou. They have high and low resolution ones. The yellow camaro is a v6 and mine is the Cyber gray ss. You can actually see a big difference in body roll between the SS and V6. The SS definitely handles better.
Gran Turismo 5 November 24th, 2010 Nezacant Gaming Lounge 562 04-21-2011 09:23 PM
CAMAROS RACING - ROLEX GRAND-AM RACE ON NOW!!! "prima"Donna The Sports Lounge 2 08-07-2010 05:22 PM
Anyone going to the Dover NASCAR Race this weekend? Hopper Off-topic Discussions 3 05-13-2010 12:14 AM
QTP GM EFI Race Series Raceway Park NJ 10/24 Quick Time USA - NY / NJ / PA 0 10-09-2009 09:04 AM
Donohue to race Camaro heavyt100 Camaro Motorsports Discussions 2 09-18-2009 11:56 AM
