04-16-2024, 01:56 PM | #1 |
Drives: 2010 2LT RS Camaro Join Date: Jul 2016
2010 RS Rims/Tires
Hi...stupid newb questions here...
Little back ground... JUST picked up a 2010 2LT w/RS like 3 days ago. Has x4 brand new tires. They put 4 new tires on the vehicle. (Of course they are the cheapest Ironman things you can get.) All the rims look like stock so I do not believe they replaced any of them. 245/45ZR20 103W on Front. 245/45ZR20 103W on Back. Yes....all same 4 tires in a square setup. I did some reading through posts and found the stock list for the 2010. And I have come to learn that Stock has offset tires/rims (245 F vs 275 R). And you can run a square setup with 245s all around because the 245s will fit the rear too. BUT the 275s will NOT fit the front rims. 1 - Is that correct? 2 - If that is correct - then is there a way I can measure the size of my RIMS without disassembling one of the 'rear' tires. Thank you. |
04-16-2024, 02:03 PM | #2 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
You may have four front wheels on the car. Measure the inside of the tire barrels to see if they are the same width. Stock wheels are 20x8 and 20x9. You can also look on the back of the wheel and see if you see an 8j or a 9j. 8j would be an 8 inch wide wheel...
2010 SS - Kind of an On3 kit, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
04-17-2024, 09:19 AM | #3 | |
04-17-2024, 06:36 PM | #4 | |
Drives: 2012 camaro ss Join Date: Sep 2018
GPI Powered
