02-19-2021, 08:36 PM | #1 |
Valkyrie14
Drives: Chevrolet Camaro SS Join Date: Mar 2020
Permanent CEL code
Yeah so ever since I did my AGP dual pump the CEL has been on for the FP sensor. I recently reintegrated the FP sensor on the fuel regulator. I wired it to the OEM harness on the tank. The light is still ON!
I cleared the codes on my HPT. But the light stays on. I ran diagnostics and cleared again. Now the code is P069E FPCM requested MIL illumination & P018B FP Sensor Circuit range/performance. Both say pending, current, permanent. I’m used to the CEL being on since December, would like to get it off. Anyone see this before? What worked? Is my sensor not working?
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
02-22-2021, 11:08 AM | #2 |
Valkyrie14
Anyone?
02-22-2021, 11:28 PM | #3 |
Banned
Drives: 2010 LS Join Date: Feb 2021
Permanent means it won't clear when power to the ECU is removed. A pro scan tool is
needed to clear PERMANENT codes, is all. However, since it's from the fuel pump control module, it will come right back on until the sensor issue is fixed. If you fixed it, you need a good scan tool to clear the DTCs. If you get a cheap $20 Walmart hand-held scanner, it probably won't clear the permanent DTCs. |
02-23-2021, 06:25 AM | #4 | |
Valkyrie14
02-23-2021, 09:09 AM | #5 |
Valkyrie14
So dealership wants to charge me to run a full diagnostic on my car. Um, no thanks. Last time I was in there I had to explain to them what a leak down test. My car is somewhat modified and they like to waste my time.
Anyone know of an OBD II scanner I can buy that will clear my permanent code without costing $1000?
02-23-2021, 09:43 AM | #6 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
Two questions:
1. Is your fuel pressure reporting to HPTuners? 2. Have you licensed your FPCM? Checking my tune file, I can see that I have both of those codes set to NO ERROR REPORTED and the SES ENABLE box has been unchecked. P069E you will find in the normal tune file under Engine Diagnostics/DTCs P018B you will find under Fuel System/DTC (only can be removed if you licensed your FPCM)
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
02-23-2021, 09:50 AM | #7 |
Keep in mind a permanent code will always show up when you run a DTC scan. HPTuners just allows you to stop that specific code from throwing the CEL on the dash.
02-23-2021, 05:44 PM | #8 |
Valkyrie14
Thanks I am going to see if I can figure this out on HPT, main goal is to get the CEL to go off.
