10-06-2019, 08:27 PM | #1 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
Cam question
For those that have cams or have a great deal of knowledge about them will you give me some in-site on what is the biggest stage cam that I can install and still maintain everyday drive ability. Of course I will install the supporting mode with it (valve springs, pushrods, gears, etc..). I currently have CAI intake, ported throttle body, Texas speed 1 7/8 LT headers with off-road connection pipes and a tune. Current power to wheels when put on the dyno was in the 440 range. I have a 2010 2SS/RS M6.
10-06-2019, 08:29 PM | #2 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
Texas speed stage 4
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
10-06-2019, 11:55 PM | #3 |
Drives: 2010 SS/RS M6 BIG cam Join Date: Mar 2016
Stage 3 cams for 5th gen are safe bets , stage 4 are getting close to ptv clearance but still fine in most cases
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
10-07-2019, 04:53 AM | #4 |
Drives: 2014 Camaro 2SS Join Date: Feb 2015
For daily driving, stick with a cam you can use beehive springs with.
10-07-2019, 08:20 AM | #5 |
Drives: 2010 Chevy Camaro 2ss/rs TF edition Join Date: Feb 2019
I've heard excellent things about GPI cams and will be going with a stage 3/4 this winter. People rave about the drivability even being a big cam
10-07-2019, 11:59 AM | #6 |
GPI Sales Consultant
First - let's get something out of the way. Forget this whole "stages" thing that people will talk about. Every cam designer "stages" their cams differently, so the "stage" is basically meaningless. For example, I have a GPI SS3 in my car, which is bigger (more duration, more lift, more overlap) than a BTR Stg4. When comparing camshafts just look at the actual @ 0.050" lift values to compare apples to apples when looking at duration and lift.
When comparing driveability of a camshaft you want to look at overlap @ 0.050" as a good measuring stick between camshafts. Negative overlap up to maybe 4* overlap essentially should drive like stock, up to 10* is very reasonable (mostly a noticeable idle, and very mild "cam behavior" such as light shudders at low rpm and load), up to 20* is starting to get into some compromises (fuel smell at idle, some low rpm light load shudders, some difficulty at parking lot speeds with bucking in M6 cars, decreased fuel economy), and 20+ degrees overlap things get even more rowdy. Something to keep in mind, M6 cars will "show" their camshafts driveability a lot more than an automatic car. Auto cars have the torque converter acting as a nice dampener at low speeds, where bigger camshafts behave their worst. So, a big cam in an auto car at parking lot speeds is no big deal, but with an M6 car you need to be ready to slip that clutch a bit when creeping along. Knowing how to calculate overlap will be very helpful as you compare camshafts. The formula would be intake duration + exhaust duration (@.050) divided by 4, minus the LSA, times 2. For my camshaft, that's 233 (intake duration) +253 (exhaust duration) /4 = 121.5 - 112 (LSA) = 9.5 * 2 = 19* of overlap. Everybody has a different opinion on what's "streetable" - I would consider 19* getting towards the upper end of what's "streetable" with an M6 car - but still very reasonable when tuned properly. Speaking of tuning... The camshaft has a whole bunch to do with that, but just as importantly is the tuning. For example, I put a lot of effort into tuning my GPI SS3. My tuner did a fantastic job with the car, WOT fueling and spark are spot on, and it was far better than 95% of tuners would ever do with respect to driveability. Because I like to tinker, I have spent countless hours refining and perfecting the tune. As a result, the car drives very, very well. I have driven cars with half the overlap that drive twice as awful - it just takes some time to really dial in a combination. So, when you choose a cam, you should think about who is going to do the tuning, and if they will do a job you're happy with. I strongly encourage you to give the fine folks at GPI a call. Not only do the have some of the very best camshaft grinds you could hope to stab into your LS3, but they also provide incredible customer service before and after the sale. Finally, and most importantly, they have a remote tuning option for their customers. Their calibrators know exactly how to make their camshafts behave, and have driven some GPI remote tuned cars I can vouch that they do an excellent job.
Got a question about a GPI product? Feel free to shoot me a message! |
10-07-2019, 01:05 PM | #7 |
Also, be honest with yourself in respect to what your really doing with the car. It's easy to over cam a daily driver. Let GPI or whatever cam grinder you go with know what your goals are and how you will be using the car a majority of the time. Big cams that make big numbers on a dyno at 7000rpm isn't always the best choice. You want power under the curve for driveability.
10-07-2019, 10:49 PM | #8 |
Drives: Silver 2014 Camaro 2SS Join Date: Dec 2018
I went with “stage” 3.2 TS VVT CAM. And honestly I would have been more comfortable with TS stage 2 or 1. I DD my Camaro practically everyday. I think a smaller cam would have been more enjoyable for my application. I have d*** for power under about 3500 rpms. Mine Camaro is also L99, so I have a high rpm stall that doesn’t help. I’ve always had a bad habit of going big or going home. Lol.
2014 Silver 2SS L99 with Roto-Fab CAI, Kooks LT Headers, Kooks Cat-less 3” exhaust, TS Stage 3.2 VVT CAM, Circle D 3200 Stall, E85 Kit, FIC 850cc injectors and Elite Engineering Catch Can. Dynoed at 478rwhp.
10-08-2019, 04:51 AM | #9 |
The LS3 does very well with smaller cams. You'd be surprised how much power you can get with a mild cam. Besides, HP let's you brag, torque wins races.
10-08-2019, 05:42 AM | #10 |
Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
There's nothing wrong with big cams when set up and tuned properly. Equally important are the relating components. My current cam is quite large and is much more driveable than previous stage 3 and 4 cams I previously ran. Some may disagree but get rid of aluminum rockers on a street car.
10-08-2019, 07:45 AM | #11 |
What's the point in a big cam if your peak torque is at 6000rpm or higher. Beneficial if your a track only car and launch at 3500rpm or more. But in a street car that is daily driven, with the occasional track pass, big cams are stupidly annoying to drive. Very little off idle torque to get the car moving. Stall converters help, but driving around town or just all around daily driving, your never in your power band. It's not all about how much power a car makes at WOT on a dyno, because realistically, you will never be driving your car like that. Seems all people care about are big dyno numbers which don't really mean anything other than bragging rights.
10-08-2019, 08:10 AM | #12 |
It all depends on the cam grind and supporting mods. I can only speak for myself but when I went with a"big cam" on my daily driver I had drivability issues, needed high idle, had to add a vacuum canister for power brakes etc. etc. After I went over my issues with Kip at Cammotion he ground me a new one, just as "big" and it made a huge difference. Idle was normal again, no more vacuum issues and driveability was much better than with more popular stage 3 and 4 cams I ran before. Perhaps we have different thoughts on what a big cam is, typically when someone says big cam I think of high lift. Mine is 720 on the intake and 714 exhaust, perhaps that's not big.
10-08-2019, 08:34 AM | #13 |
Duration@ .050" is usually what people are referring to as cam size. Anything over 228 on the intake duration is too big of a cam IMO. Also, different cam grinders have different ramp rates to their grinds. Lunati and comp cams grinds are generally aggressive with a rate of 50 deg. Aggressive cams are hard on valve spring and the valvetrain as a whole, and require frequent inspection of spring pressures because they wear out springs, and require dual valve spring to aide in controlling the valvetrain. Cam motion cams are a bit easier on their ramp rates with about 60 degrees making them easier on the valvetrain and spring longevity, and usually allowing the use of beehive springs, resulting in a quiet and more stable setup. If you know what your trying to do with the car, its easier to pick out cams that suit your needs. Big cams that make 520hp but only 430lbft of torque won't be any faster than a car that makes 470hp and 450lbft of torque (all else being equal). It really all boils down to what your using the car for and where your intend to use your powerband. Street cars do not need huge cams to make power and be a fast car.
10-08-2019, 09:29 AM | #14 | |||
I'd interpret that different though - with all else being equal meaning each car is the same power, weight, traction, and the driveline (converter, gear) is optimized for the combo. In that case, the 520hp car is really gonna stomp on the 470hp car. Overall, I get your point. I see plenty of guys putting donkey dick cams in cars that aren't otherwise really optimized for them, and they'd likely be better off with a more appropriately sized stick. Heck, I bet half the cammed cars out there rarely if ever truly get revved through their full powerband to the very top where they really should be shifted. Don't get me started on the "shift at peak torque" crowd! But, the big cams have a place for guys that are willing to build the car to suit that choice, and use them as intended. They certainly don't have to drive like crap and be dead on the bottom end. Just food for thought - I enjoy a good conversation like this.
