Old 03-30-2019, 03:47 PM   #1
Blueovalman
Blueovalman's Avatar
Drives: 2012 V6 Camaro 2010 Camaro SS
Question What is code P062F 2012 Camaro 3.6L V6??
Our 2012 Camaro 3.6L V6 was parked and when I went to try to start it would not start. I waited 30 mins. and it started. I drove it to get the code read and the code read P062F Internal Control Module EEPROM Malfunction. The only advice I received was this is a strange code and I would need to take our 2012 Chevrolet Camaro to a Chevrolet dealership service department for diagnosis. Does anyone have any ideas what this code means? Opinions?
Mr. Clean
Blueovalman is offline   Reply With Quote
Old 03-30-2019, 03:50 PM   #2
Blueovalman
Here is what the code scanner read.
Mr. Clean
Old 03-31-2019, 07:03 AM   #3
Blueovalman
Does anyone have any ideas please? This code is tough to diagnose as I read.
Mr. Clean
Old 03-31-2019, 10:01 AM   #4
cawengr
Drives: Classy
Pretty good trouble shooting process at this site, Good Luck
https://www.troublecodes.net/pcodes/p062f/
cawengr is offline   Reply With Quote
Old 03-31-2019, 08:02 PM   #5
Blueovalman
Thank you I will check that out to see if it will help us diagnose the problem. Unfortunately our Camaro will still not start.
Mr. Clean
Old 04-06-2019, 04:42 AM   #6
Blueovalman
I diagnosed our Camaro and I found that my Genuine GM battery had a bad cell in it and was not holding voltage. I had to tow our Camaro to our local Chevrolet dealership service department and I had them diagnose it and they replaced the Genuine GM battery and had to reset the transponder and reflash the ECU and it starts now that was the issue. The Chevrolet dealership service department also found a major motor oil leak the crankshaft and camshaft seals are leaking and need to be replaced as soon as possible. I knew I was losing motor oil some where between oil changes.
Mr. Clean
Old 04-07-2019, 08:02 PM   #7
ForgotUsername
Drives: 2010 Camaro RS LT2
What mileage is your camaro?
Any tips on where they saw oil coming from, or how any of us could check to see if we have the same condition?
ForgotUsername is offline   Reply With Quote
