04-15-2023, 08:14 AM | #1 |
Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
Correct Differential Fluid for ZL1
NOT a 1LE
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top. |
04-15-2023, 10:21 AM | #2 |
Drives: Wild Cherry LT1 Join Date: Dec 2016
Here ya go… if I remember correctly, it took about 1.2 - 1.3 quarts to fill my ZL1 convertible.
04-15-2023, 12:54 PM | #3 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
The ZL1 rear diff fluid is the same as the ZL1 1LE and SS 1LE. As shown above: 10-4034
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
04-15-2023, 01:53 PM | #4 |
TY all, I knew it was different
04-18-2023, 10:56 AM | #5 |
Drives: 2023 ZL1 A10 Join Date: Nov 2021
When I was in for the 1st oil change, and Diff service, I waited 2 1/2 hrs. for them to get this from there other Dealership, #19352759 , the service advisor said 2023 fluid is new and he wanted to put the new fluid in .
2023 ZL1 A10 Shadow Gray Metallic
04-18-2023, 11:51 AM | #6 | |
Drives: 2023 Chevrolet Camaro 1SS Join Date: Dec 2022
Looking that part number up I can't tell if it has the Limited Slip modifier in it or not. By label alone, it appears to be the same stuff I put in my diff without the LS additive: https://a.co/d/gPya5YQ |
04-18-2023, 08:41 PM | #7 |
Drives: Chevy camaro Join Date: Jan 2022
It doesn't say anything about it being for Limited Slip.
Glenn
2017 Camaro 2LT RS Convertible |
07-01-2023, 06:42 PM | #8 |
Drives: 2023 Chevrolet Camaro ZL1 Join Date: Nov 2021
New part numbers...
88900401 lubricant 88900330 additive You'll need 2 bottles of the lubricant and 1 of the additive |
07-01-2023, 07:15 PM | #9 |
Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
This the Canadian part # with friction modifier already added
07-01-2023, 07:45 PM | #10 |
Drives: 2020 Rally Green ZL1-1LE Join Date: May 2020
I sure hope they dont quit making it WITH the ELSD friction modifier in it!
07-01-2023, 11:56 PM | #11 |
Drives: 2023 Camaro ZL1 Join Date: Jan 2023
Why does this simple task have to be confusing? Even posted here there are some different answers. The darn owners manual and high performance manual does not list the recommended fluid. Indicates see the dealer.
2023 Camaro ZL1 6MT Summit White
07-02-2023, 01:37 AM | #12 | |
Drives: 2022 Vivid Orange LT1 M6 Join Date: Apr 2018
Task is confusing because GM recommends the wrong fluid if you go to them. At least in Canada they do. Not sure if its the same for USA. |
07-02-2023, 05:09 AM | #13 |
Thank you Al Oppenheiser!
Drives: Red Hot A10 ZL1 Convertible Join Date: Jun 2017
Both ELSD and LSD use the 10-4034 fluid with friction modifier.
07-02-2023, 06:49 AM | #14 |
Drives: 2023 Sharkskin 2SS Join Date: Oct 2022
I just did the 10-4034 fluid change on the 2023
Next change will get the new synthetic fluid +FM hard to keep up with the spec changes ETA: did a search for fluid on a 2022 are they are phasing out the 10-4034 for the synthetic ?? https://parts.gmparts.com/search?bod...,304108,114348 Last edited by 302crossram; 07-02-2023 at 08:22 AM. |
