08-14-2017, 07:01 PM | #1 |
Drives: 2013 zl1 Join Date: Aug 2017
Road course tires
2013 Zl1 I have the stock Gy f1 g2s and trying to determine if I wanna go with Toyo proxes, sport cup 2s or pirelli zero. Any opinions?
Sent from my HTC 10 using Tapatalk |
08-15-2017, 06:55 AM | #2 |
Drives: 2SS 1LE Silver w/Recaro NPP Join Date: Feb 2014
Describe how you plan to use the tires.
Do you need to drive on the street as well? How much experience do you have at the track? Do you drive in the winter? Do you have a budget?
-BtrBimmer
'14 2SS 1LE NPP Recaros |
08-15-2017, 08:07 AM | #3 |
KaBoom1701
Toyo R888's.....
Mods:
08-15-2017, 02:56 PM | #4 | |
08-15-2017, 02:58 PM | #5 | |
08-15-2017, 03:03 PM | #6 |
Drives: cars Join Date: May 2011
That would handle horribly and be unsafe with varied levels of traction. All or nothing.
08-15-2017, 03:05 PM | #7 |
08-15-2017, 04:06 PM | #8 |
Drives: 62 Chevy & 2021 1SS/1LE manual Join Date: Aug 2010
as mentioned, dont mix and match compounds. the street P zeros are not an upgrade from what you have now. to run on track and street, the RE71s might be a good option. one of the guys at the camaro fest was running in advanced class very well on that tire.
08-15-2017, 04:22 PM | #9 |
The re71 widest option is 295, stock is 305, I definitely don't wanna go down in width. They proxes are track only. How will they perform on street.
08-15-2017, 04:54 PM | #10 | |
im assuming that dearborn is michigan. i would not do the 888s. they are better than slicks in the wet but not good for wet streets and pot holes and such. everyones situation is different and you could get different opinions, but i would not do it. they would wear out so fast you would be buying tires a lot. if this is what your thinking, just buy a set of wheels and tires for track. put em on and drive to the track and back home, then take em off and put your street wheels and tires on. |
08-15-2017, 06:13 PM | #11 | |
08-15-2017, 07:44 PM | #12 |
if you have to do one set, just get MPSS and be done with it. its like the brake discussion. i want racing brakes but i dont want squeal or dust... i want R comp tires but i want a tire that goes 30,000 miles and is good in the wet. that tire doesnt exist.
08-15-2017, 08:11 PM | #13 |
KaBoom1701
The OP asked about track tires.... The R888's are the best track tire for the ZL1 at this time. I'm looking forward to seeing if the new GY's G3's will be made in are 35 series tires. Whats all this road tire talk? He didn't ask about a good track and street tire.The OEM GY's do this just fine IMHO. Just fyi I'm running NITTO RT555 G2 right now and with a 30 series tire to boot. Nice tire but they do get slippery when heated up on the track. I plan on going back to the extra set of GY's I have when these burn off. I'd like the R888's but they are pricey. I'm hoping the GY's G3 are available by the time I need them. Just my .02
Mods:
08-15-2017, 08:46 PM | #14 |
What do you mean they take too long to warm up? If they are taking multiple laps to warm up you can still push quite a bit harder on the stock tire. The tires should be up to temp by the first lap and getting greasy by the 3rd or 4th lap.
