JUICEDMOTORSPORTS
Old 02-06-2015, 06:50 PM   #1
ADM PERFORMANCE
Drives: Anything I want
ADM ZL1 E85 TEST
This is 2 years old....But very informative
ADM Performance has teamed up with Andy at Squash Performance to fuel its New Shop 2013 ZL-1
For both current mods and possibly the highest horsepower ZL-1 Ever.
The recipe for fuel consist of Squash twin 400LPH fuel pump module ,Weldon boost referenced regulator,KenneBell 20v Dual Boosta-pump,Injector Dynamics ID 850 Injectors(For now),A lot of wiring!
Here is the car -
ADM PERFORMANCE is offline   Reply With Quote
Old 02-06-2015, 06:52 PM   #2
ADM PERFORMANCE
Here is the pre dyno
484 rwhp and 465 rwtq
Here is prior to mods starting dyno- 80 miles on car
Old 02-06-2015, 06:54 PM   #3
ADM PERFORMANCE
Coming apart
Old 02-06-2015, 06:55 PM   #4
ADM PERFORMANCE
Out with the old and in with new
Old 02-06-2015, 06:56 PM   #5
ADM PERFORMANCE
Old powering system and New
Old power system versus new
Old 02-06-2015, 06:57 PM   #6
ADM PERFORMANCE
Here is the parts list and car
2013 Shop TEST E85
New ZL1 combo:
Dual 400 lph system
Kennebell Dual boostapump
Weldon regulator
Injector dynamics ID-850
Ported blower inlet
Ls3 throttle body
ADM Street Intake system
2.38 pulley
14-15 psi(should be with no cam and exhaust mods)
ADM Heat Exchanger
Stock exhaust
Stock cats
Stock cam
Stock converter
Stock lower pulley/balancer
Stock 6l-90E Automatic transmission
Old 02-06-2015, 07:00 PM   #7
ADM PERFORMANCE
The results
So after I spent a bit of time seeing how much timing you can get into a ZL1 ON E-85 as compared to a ZL1 ON 93 Octane I have come to realize that E-85 WORKS GREAT FOR THESE 1.9 LITER BLOWER CARS!
With the 2.38 pulley and the LSA Blower spinning 21,300 rpm at 6500 the boost with stock 4 catalytic converters,stock 2.5" exhaust,stock cam,ADM Ported Blower Snout,LS3 Throttlebody,ADM Street Intake makes an averge of 14.7 psi boost.
Peak Torque is at 14.93 psi at 3800 rpm 633 RWTQ
Peak Power is at 14.72 psi at 5900 rpm 624 RWHP
Timing at Peak torque is 19
Timing at Peak Power is 27
Here ya go:
Torque compared to stock:
GT-500 at same boost :
Old 10-21-2015, 10:32 AM   #8
mlee
Moderator
mlee's Avatar
Drives: 2019 Crush ZLE
Just found this... may be my next mod.
Old 10-21-2015, 11:04 AM   #9
Scuzz
Scuzz's Avatar
Drives: 2012 Camaro SS
Getting my e85 done as we speak
No brainier once they opened up a e85 gas station 5 min from house
2012 Camaro SS Automatic
AGP Twin Turbo LSX427 / ADM Magic / 4L80
“1318 Rwhp 21.70 lbs of boost”
On 22.9lbs so ~1345ish?
Scuzz is offline   Reply With Quote
Old 10-22-2015, 08:33 AM   #10
ADM PERFORMANCE
Old news mike,Old news!
Old 10-22-2015, 08:57 AM   #11
mlee
Moderator
mlee's Avatar
LOL... that's why I just call you
Old 10-22-2015, 11:10 AM   #12
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
I plan on going E85.
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake | Pfadt Suspension | DSS 1000hp axles |
Tuned by Ryne @ CMS E85: 734rwhp/636rwtq (mustang dyno)
Jeff_SS is offline   Reply With Quote
Old 10-22-2015, 01:58 PM   #13
ADM PERFORMANCE
Old 10-22-2015, 02:13 PM   #14
ZYBORG
Lets roll...
ZYBORG's Avatar
Drives: 14'
Andy, did you ever cecked out the PM and/or email I sent you about a month ago?
ZYBORG is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
