Old 01-02-2017, 03:08 PM   #1
Da2ss
Da2ss's Avatar
Drives: Blueray metallic 2ss
Turbo mpg
Is it common for a turbo car to loose 5-6 mpg under normal driving conditions at 70 with cruise set afr is reading 14-15 I have a single top mount 7475 comp zl1 pump 1000 cc injectors or is it it in the tune
Da2ss is offline   Reply With Quote
Old 01-02-2017, 05:09 PM   #2
swiftkart
swiftkart's Avatar
Drives: 2010 SS/RS LS3 M6
In my experience with turbo cars and bikes, they normally get stock mpg or 2 to 4 mpg better, especially if you are talking 91/93 pump gas, I would look at the cruise timing in the tune if your afr is correct.
swiftkart is offline   Reply With Quote
Old 01-02-2017, 05:41 PM   #3
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 13 Camaro LSX427 TT
Are you looking at the in-dash MPG represented or actually doing the calculations?
I did not lose any MPG when adding the turbos to the car and having it tuned. But when I added the cam, MPG took a big hit (4MPG).
In excess of 1,000WHP
LSX427 | AGP 65/65 TT | BTR Equalzer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | NGK BR7EF | DSX Flex Fuel Sensor | AGP's Fore Triple Fuel | Monster LT1-S Triple | 3.25 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates
dreksnot is offline   Reply With Quote
Old 01-02-2017, 06:06 PM   #4
Da2ss
Da2ss's Avatar
I was already cammed getting 22 mpg highway now getting 15 in the dic I can see the needle move every time I take the car out ill have my tuner check it out in a few days
Old 01-02-2017, 07:47 PM   #5
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
You still using regular fuel or did you switch to E85?
HOJO is offline   Reply With Quote
Old 01-02-2017, 07:49 PM   #6
Unreal
Drives: 2006 Z06
Every car i've added turbos to got better mileage. Not normal at all to lose mileage.
Nick
Corvette Z06 -1200ish rwhp
Old 01-02-2017, 08:09 PM   #7
Da2ss
Da2ss's Avatar
Still using 93octane I wasn't expecting much change at all during normal driving conditions up until now every mod has actually gained mpg.... for all the tuners in the group what would you suggest afr is solid while cruising 14-15 at idle it's 16-17 and will gas you out with the smell...no cats of course but wasn't this bad before the turbo
Old 01-02-2017, 08:25 PM   #8
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Like others have said, with a turbo, and a proper tune, your gas mileage should be the same as it was before. Get your tuner to have another look.
Your AFR should be fluctuating, up and down, around 14.7, at idle and cruising speeds.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 01-03-2017, 11:54 AM   #9
JANNETTYRACING
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Don't trust the DIC, do a hand calculation and see where it really is.
And you have to keep your foot out of it.
power enrichment fueling can be coming in too early.
Ted.
www.jannettyracing.com
Celebrating 34 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 01-03-2017, 06:43 PM   #10
JantzenOKC
JantzenOKC's Avatar
Drives: '13 2LT/RS Twin Turbo
I agree definitely not normal. My gas mileage got a little better on the highway and a little worse around town. I'm sure the converter has a lot to do with that though.
I'm a v6 not a v8 but I average 30-32mpg on highway trips. Gotta love turbos.
3.6L Twin Turbo V6
Garrett GT28 turbos -- Jacfab forged connecting rods -- Diamond forged pistons(10.5:1) -- Alky Control Methonal Injection -- CircleD 2E triple disc torque converter -- BMR suspension
10.75 @ 131mph
JantzenOKC is offline   Reply With Quote
Old 01-03-2017, 07:30 PM   #11
caper
Drives: 2010 IOM 2ss/RS
when i added the turbo and tuned my mileage went way down....way down.
Turbonetics running 8lbs boost at 563/559 tuned by Cunningham installed by K&M w/cat-muffler delete, ACS splitter, Fesler GFX, MPD1 spoiler, Custom painted Rally stripes, Cordon CR1 wheels 275/315s, Hotchkiss comp sways and end links, Barton shifter
caper is offline   Reply With Quote
Old 01-03-2017, 07:51 PM   #12
Da2ss
Da2ss's Avatar
Mpg
Because your playing to much or during normal driving condition
Old 01-03-2017, 08:28 PM   #13
caper
both...i average about 12mpg based on the dash. but maybe thats not so accurate...but it drinks allot so it might be
Old 01-03-2017, 08:33 PM   #14
1KillerSS
1KillerSS's Avatar
Originally Posted by JANNETTYRACING View Post
And you have to keep your foot out of it................Ted.
What?? I call BS!
Build thread
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
