04-23-2021, 01:34 PM | #1 |
Drives: 2010 2SS/RS Camaro Join Date: Dec 2020
OE Boston Acoustic 2 way speaker connector
The OE Boston Acoustic Parcel shelf speaker has a mid-bass channel (2 wire) and a high channel (2 wire) for a total 4 wire connections per speaker. To successfully replace the factory 6x9 you must get bi-amp speakers. Bi-amp speakers have to separate sets of terminals. First terminal set (2 wire) feeds the woofer and second terminal set (2wire) feeds the tweeter. The factory male connection plug at the end of the speaker harness has the four wires and attaches directly to the speaker. The factory speaker has the 'female' portion of the connection plug molded into the speaker's frame.
Bi- amp speaker can be had from suppliers like Kicker Q-Class 44QSC694, Sony XSGS6921, Massive Audio P69X and others. (I am replacing my stock speakers with a pair of used Lanzer brand CX69.3, bi-amp speakers I found on eBay UK.) If we can identify the correct female-end connector that mates to the factory harness male-end connector we can make a quick disconnect set-up like the factory. Does anyone know what female plug we need to buy that fits into the factory stock female-end plug? Last edited by lvlender; 04-25-2021 at 12:38 AM. Reason: more detail |
04-26-2021, 03:54 PM | #2 |
Drives: 2011 RS 2LT Join Date: Dec 2020
Hi,
I'm not sure. So I bought the complete kit from sub thump. I'm going to do the amp and back speakers some day. lol Shipping was fast and no problems. JMO |
04-26-2021, 04:56 PM | #3 |
Banned
Drives: 2010 LS Join Date: Feb 2021
You do not "NEED" to get Bi-Amp speakers. You can run without the HI, or wire the HI
side to a separate tweeter. If you happen to get a speaker out warning without using the HI side, then put a 2-ohm or 4-ohm resister across the HI leads. |
04-27-2021, 12:43 PM | #4 |
Drives: 2015 Camaro 2SS Green Flash Edition Join Date: May 2017
I used that kit to connect all of my aftermarket speakers. They do the job quite well.
StarSaber Mk. II
IG: StarSaber85(https://www.instagram.com/starsaber85/) Performance Mods: CAI, Inc. Cold Air Intake; ADM Racing Scoop; Bo White Ported Throttle Body; GPI Ported Rod Mod Intake; Kooks 1-7/8" Headers with Catted Connections; Solo Mach XL Axle-Back Exhaust |
