04-06-2024, 08:59 PM | #1 |
Drives: Chev camaro ss Join Date: Nov 2022
4L60e issues
2010 SS cammed with a Circle D 35-3600 stall.
Car revs up but barely moves then if continue on the throttle it will speed up. Seems like trans is slipping. My question is anyone have a circle D and is it possible that is the problem or did I cook the trans? I am not easy on it and spin the tires often. only have a few hundreds miles since I did stall. The car kind of spun slightly when this happened under a normal excelleration from a stop. Check engine light came on but no noises. When I shift to S mode I cannot change gears and the S flashes. In neutral if I rev it it slighly moves forward. Any help is appreciated. |
04-06-2024, 10:21 PM | #2 |
Drives: ABM #93 Join Date: Oct 2018
I assume you mean 6l80 issues?? Or did you do a transmission downgrade swap?
It certainly could be converter related. Unfortunately sometimes when the converter goes it wipes the trans with it.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
04-07-2024, 08:10 AM | #3 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
When my converter failed it had all kinds of weird shifting issues but still moved the car. It did eventually throw a code.
04-07-2024, 10:46 AM | #4 | |
When my Camaro did that exact same thing, I was able to limp home. When we scanned it and pulled the codes, it was the "input speed sensor" in the TECHM unit that went bad. See this info. Could also be your pressure switches. The codes I got were P0700- TCM requested MIL, and P0716-input/turbine speed sensor circuit range/performance. Good luck.
https://www.sonnax.com/tech_resource...m-applications https://d2q1ebiag300ih.cloudfront.ne...f?v=1539892125
