![]() Drives: 2010 Camaro SS Join Date: Nov 2012
Any chance I will pass inspection
I have a 2010 camaro ss
I have a new era performance CAI I have XS power LT's with no cats, no resonators, and no mufflers. I have SCT programmer with a custom tune. I have a friend who will pass me at a inspection station The car keeps throwing fuel trim lean bank 1,2. Is this a computer or mechanical issue? What to do? Im going crazy,I cant get a inspection sticker |
![]() Drives: 2010 RS/SS Join Date: Dec 2010
I don't know what MA testing is like but if they are hooking up through the DLC like they do here in NC it is not going to pass if there are codes and/or readiness monitors are not set. If it is just a visual inspection and you know someone who will overlook the cats then that is one thing.
Who did your tuning? Sounds like they need to tweak it some more. If you're getting lean codes then it needs to be adjusted in the tune barring any mechanical issues. How long have you had the headers and how long have the codes been on? |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Unless your friend will just rubber stamp you, there's no way in hell you'll pass. Your car, in current form, will violate every aspect of emissions testing. That means visual, readiness codes, sniffer, everything.
As Kelly stated, if you have a custom tune and you're still throwing codes, you have a tuning issue. Contact the shop that did the tune and have them fix it.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
+1. Sounds like a for sure fail to me. I'd contact your tuner about the lean codes asap. You don't want to be driving around lean period.
#5 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
OK I checked, I tuned your car 6/2011, if your getting lean codes I would start by cleaning the MAF Sensor with MAF Sensor Cleaner. Also Check for Vacuum Leaks and Exhaust leaks. Clear the codes and Log the Car and send me the Logs Per the instructions. Not sure why you didn't ask me first? Ted.
www.jannettyracing.com
Celebrating 35 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com Last edited by JANNETTYRACING; 11-13-2012 at 11:35 AM. |
#6 |
![]() ![]() ![]() ![]() Drives: 2010 CAMARO SS Join Date: Apr 2010
your problem might be a catch can drain valve open if you have one,,,it will throw that code
#7 |
![]() ![]() ![]() ![]() Drives: 2010 Camaro SS 2SS Join Date: Aug 2009
Why do all that to your car and then worry about inspections? No mufflers in Texas will get you tossed under the visual, I found a place that green lights me before I ever made the decision to mod things that would fail...
#8 |
![]() Drives: Camaro Join Date: Aug 2012
Funny...I know a Bourque that lives on Cape Cod.
Anyway, no you will not pass until you get the codes cleared out and do the GM drive cycle to set the readiness statuses. If you have a very friendly inspector he may let you pass without the visual, but somehow doubt it given that your car has LTs and nothing but straight pipe the rest of the way. A friend inspector that will deliberately pass you even after he hears your car sure, a normal inspector will not after hearing the car start. |
#9 |
had a similar problem, with trim banks lean, kept throwing an engine light even after a retune, ended up they pressure tested the valve springs and found 3 weak springs, put all new springs in and that solved the problem, thank goodness it was under warranty
#10 |
Drives: Florida Speed & Power Join Date: Jan 2011
Move to FL, no inspections
![]() Kidding. No you will not pass @ its current state. |
#11 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
No inspection in Illinois either lol and as long as you don't have a cel light your all good.
Looks like Ted is going to take care of you. Don't worry.
#12 |
Your stock valve springs were weak? Wth? I thought stock springs lasted a lifetime. You must have like 200k miles on your car. Lol
432 RWHP 391 RWTQ 12.37 1/4 mile on stock tires
#13 | |
![]() Drives: 2010 2SS Camaro silver black stripe Join Date: Aug 2011
If he doesn't just put some money under the table... I don't know MA inspections as I don't live there.
AIRAID cold air intake, Borla headers long tubes stainless steel, MBPR Performance Cat back X-pipes,custom cam from Virginia Speed, CNC Ported Heads from TEA, Heritage grill
#14 |
![]() ![]() ![]() Drives: 2010 SS L99 Inferno Orange Join Date: Apr 2012
IMO OP, I would get with Ted @ JRE! The Guru could prolly straighten things out for you! Good luck!
Thread Tools | |
