Old 06-19-2016, 08:49 PM   #1
1LEVIL
1LEVIL's Avatar
Drives: 2015 SS/1LE
LS3 ticking?
Good evening everybody!
Is this ticking noise normal for the LS3? I do not remember hearing it before and I want to make sure everything is good to go.
I have roughly 15.6k miles on it. Only mods so far are solo performance high flow cats. I'd appreciate any feedback..
1LEVIL is offline   Reply With Quote
Old 06-19-2016, 08:54 PM   #2
LakeMich30
LakeMich30's Avatar
Drives: 5thgencamaro SS
I had ticking at 28000 miles, ended being fan belt pulley & tensioner and the dealer replaced anf the belt under warranty.
LakeMich30 is offline   Reply With Quote
Old 06-19-2016, 09:53 PM   #3
1LEVIL
1LEVIL's Avatar
Drives: 2015 SS/1LE
Thank you for the reply! I will take it to the dealer and have them check it out
Old 06-19-2016, 09:55 PM   #4
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Sounds normal to me, actually not as bad as others I've heard.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 06-19-2016, 09:55 PM   #5
LakeMich30
LakeMich30's Avatar
It did take my dealer 3 days to figure it out, but I was happy the ticking was gone.
Good luck.
Old 06-20-2016, 10:51 AM   #6
Brian_87
Brian_87's Avatar
Drives: 2010 camaro 2ss
My car has the exact same ticking also louder on passenger side under the car I've owned it for 2 weeks it's only got 65000kms I changed my oil to mobil 1 and mobil 1 oil filter as recommended I was thinking of adding a zinc and phosphorus additive to see if that would help?
Brian_87 is offline   Reply With Quote
Old 06-20-2016, 10:55 AM   #7
LakeMich30
LakeMich30's Avatar
Before thinking it's a belt pulley or tensioner make sure there's not a rock or something jammed in the tire tread, can also make a ticking sound.
Good luck
Old 06-20-2016, 11:05 AM   #8
Brian_87
Brian_87's Avatar
Does it at idle till around 3000 rpms if I have my window down and drive by a fence around 40 kms I can here it echoing
Old 06-20-2016, 11:11 AM   #9
LakeMich30
LakeMich30's Avatar
My belt pulley and tensioner made the ticking at idle, didn't notice at speed because it was winter, windows up at 20 degrees.
Old 06-20-2016, 04:19 PM   #10
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
If mine didn't sound like a sewing machine, I'd think something was wrong
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
