#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > Forced Induction Discussions
AWE Tuning
Old 06-19-2019, 09:12 PM   #1
DJ_BigC
Rockin' Steady
DJ_BigC's Avatar
Drives: 2010 Camaro 2SS
Edelbrock E-Force install help
This is my first post on Camaro6 so hello everyone!!
I am currently installing an Edelbrock E-Force 2650 complete base kit on a customers car at work (GM dealership).
I am currently snagged on a section in the instructions. I have read them over 50 times probably with 2 different competent techs and we are all confused as to what they are asking us to do for the same section. I noticed some of the pictures in the binder aren’t from a Camaro, some are from a GM truck and it’s throwing me off.
The front barb fitting closest the the throttle body should have a line going from there to the valley plate correct? Reason I’m asking is because the instructions tell me to run my T-Map line kit from that barb to the brake booster line.. except the brake booster line already has the modified one way check valve line going from the T off in that line to the barb behind the EVAP purge valve. So now if my front barb on the blower goes to the valley plate, my booster line with the check valve goes to the barb behind the purge solenoid then where does the T-MAP rubber line kit plug into?? I’m out of barbs haha!! It honestly seems like either that T-Map hose kit to run the factory MAP sensor does not belong in the kit of I’m missing a barb on my blower. I have 1 fitting with 2 possible connections according to the instructions.
If anyone has pics of that area of their supercharger kit that would be appreciated. Yes I looked online for pics and I cannot find any and I have also used the search functions and didn’t really find what I needed to find.
Thanks, Eric.
Eric Carrier, proud GM Technician for over 10yrs.
2010 Camaro 2SS Black, L99, SLP headers, GMPP axle back, complete JRE tune, 22" Boss 337's, Nitto Invos 5% tint, Eforce Supercharger w. 3" pulley, ADM FPCM, ID850's, JRE fuel rail mod, Eforce CAI, Moroso catch can, spark plug insulators.
DJ_BigC is offline   Reply With Quote
Old 06-20-2019, 01:19 AM   #2
SpaceCadet
Drives: '99 Vette, '02 SVT Focus
Yeah they have a couple of issues/errors with the instructions. Let-alone picture #124 being a truck..
Step #81 takes care of the valley cover PCV to inlet barb.
I believe Step #109 is correct for the brake booster vacuum. Make sure the check valve is flowing the correct direction (suck going to Booster 'T')
Correct me if I am wrong? I believe LT1 does not have an intake (T?)MAP.
So, I think Step #124 should only be for a LT4/ZL1 swap, that does.
Any fittings/barbs or wire harness leftover?
SpaceCadet is offline   Reply With Quote
Old 06-20-2019, 06:31 AM   #3
DJ_BigC
Rockin' Steady
DJ_BigC's Avatar
Another reason why I’m asking all of this is because I did not receive the short hose that goes from the valley plate to the front barb on the blower. I figured I did not receive it for a reason and proceeded with the install.. i know that’s my mess up for not doing anything about it but I have gotten and not gotten many parts before with aftermarket kits and turns out it was always for a reason... it’s no big deal it’s an easy hose to make. Now that takes care of the barb at the front of the blower to the valley plate.
I have the entire brake booster line set up the way they want it as per the instructions that’s all easy peasy but then a few steps later or before (sorry don’t have them in front of me) it says to use the front barb on the blower and go to the brake booster hardline and then attach that rubber line T harness they have that uses the factory MAP sensor. Well if i do that, I end up with nothing in my valley plate.. no check valve in the booster line and now my vacuum port behind the purge solenoid on the blower is also open but I end up with no loose connectors on the harness. We all know i can’t go from the vacuum port to the valley plate so that doesn’t take care of my unused ports.. This is why I’m in shambles right now haha.
I have to run the supplied harness for the MAF/MAP sensor because the new MAP sensor on the blower is a 4 wire vs a 3 wire. If I do not use this contraption they have which is that T off style rubber line somewhere on the install I end up with a connector that does nothing in the supplied harness? Thats no big deal mind you I can easily remove that wiring and seal the harness for a clean install.
Old 06-20-2019, 12:38 PM   #4
SpaceCadet
Did you try and reuse the stock PCV hose? On one hand it looks like (step #86) it might work.. on the other it looks like (step #81) it needs a 90 degree quick connect fitting?
Step #110 has a decent image of the brake booster hose going to the back fitting, using hose clamp. Then EVAP solenoid is forward of that.. then the front quick connect is for the PCV.
The kit did not include an additional 3wire MAP sensor? I see your point on the harness, having the additional breakout sensor ('MAP' in intake) is to move the barometric monitoring out of the MAF sensor. I still assume LT1 does not need this.
Edelbrock has good tech support service, so reach out to them for additional clarification.
Cheers!!!
Old 06-20-2019, 04:25 PM   #5
DJ_BigC
Rockin' Steady
DJ_BigC's Avatar
I reached out to Edelbrock. I got the car started by running a hose from the valley to the front barb on the blower. The car instantly set an SES light with MAP sensor codes.
The gentleman told me the MAP sensor on the blower is no longer used as a map sensor. That sensor is now solely used to measure the temperature of the air inside the blower. He told me Edelbrock is now using the factory 1bar MAP with their kit. The short hose that the instructions say to run from the front barb to the valley that i did not have in my kit is no longer used even though the instructions clearly state to install it. That hose has now been replaced with that T style rubber hose kit that they want you to install the factory MAP sensor into. You run that hose from the front barb to the valley even though the instruction clearly say to run it to the brake booster haha. He did admit to the instructions being off in regards to the PCV routing and having some non Camaro images. Even the latest revision of his instructions were still wrong LOL.
Thank you for your help.. I just hope this will help others in the long run if ever they run into these issues.
Old 06-20-2019, 08:10 PM   #6
USAFS197
USAFS197's Avatar
Drives: 2018 Audi TT RS
Is this on a SS or a ZL1?
2018 Audi TT RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped).
2019 Audi RS3
About as fast as the TT RS
2019 Camaro ZL1 1LE
Sold
2018 Camaro SS 1LE
Sold
2019 Corvette Z06
Sold
2021 Charger Hellcat Redeye Widebody
Sold
USAFS197 is offline   Reply With Quote
Old 06-20-2019, 10:43 PM   #7
DJ_BigC
Rockin' Steady
DJ_BigC's Avatar
This was for a 2018 Camaro 1SS w. the LT1.
Old 06-21-2019, 01:38 PM   #8
USAFS197
USAFS197's Avatar
Nice. Looking forward to seeing the results of this blower on our cars.
2018 Audi TT RS
2019 Audi RS3
2019 Camaro ZL1 1LE
Sold
2018 Camaro SS 1LE
Sold
2019 Corvette Z06
Sold
Sold
Old 07-30-2019, 02:31 PM   #9
ssmofo
ssmofo's Avatar
Drives: Chevy Camaro
Another reason I'm gonna run a whipple. Direction the are confusing suck, even after you drop serious coin.
ssmofo is offline   Reply With Quote
Old 08-19-2019, 01:12 PM   #10
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Drives: 16 SS & 17 ZL1 Both Yellow
Send a message via Skype™ to EDFHOBBIES
I would refer to the 2300 directions should be the very close if not the same. You can find on the Edelbrock site easy.
Also Edelbrock answers the phone every time I call unlike whipple.. and some grandma at maggi.. since your bringing up this s#&^ I'll elaborate with my experiences.
If ya need any help I'll shoot u some picks
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber
EDFHOBBIES is offline   Reply With Quote
Old 08-19-2019, 03:19 PM   #11
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Ha, Grandma and I think she does have grand kids. I'll let her know you wish her and the grand kids well.
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
laynlo15 is offline   Reply With Quote
Old 08-19-2019, 03:52 PM   #12
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
I'm just saying an older lady answered when I asked for a release date about 6 months ago. Then an older guy in tech finished the call.. I'm close to 50 well I guess they may of smoked a lot..
Old 08-19-2019, 06:13 PM   #13
SpaceCadet
Looks like Edelbrock just updated the SS 2650 instructions last week, unfortunately there are still inconsistencies and errors..
Old 08-19-2019, 09:37 PM   #14
laynlo15
laynlo15's Avatar
She's your age. I'm in tech but I didn't talk to you. We can keep it civil, how bout that.
