![]() Drives: 2010 Camaro 2SS Join Date: Mar 2018
Tire setup
Can the 2 rear tires be rotated side to side only in the back left rear to right rear ? Planning on putting 245 In the front
![]() ![]() ![]() Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
Not if they are directional tires.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, SLP loudmouth exhaust, elite engineering catch can and many other things.
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
the stock tires are NON-Directional......however, the fronts and rears are different sizes.. but can you "rotate" the tires "right to left" (side to side) the answer is YES.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
Just to be sure, take a look at the sidewall of the tire.
If there is an arrow, then it's a 'directional' tire and cannot be swapped to the other side of the car. However odds are as Sir Nuke pointed out, the stock tires on your SS are non-directional and can be swapped from side to side. |
![]() Drives: 2014 camaro SS Join Date: Jan 2019
the stock pirellis are non directional, but there is an outside which should be noticed when mounting. you can switch left to right.
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: LT W/2LT,blue metallic Join Date: Jul 2016
bought a set of coopers at 27,000 miles where the p zeros were done.coopers are still good at 72,000 miles and never been rotated.
#7 |
I never agreed with tire rotation anyway. in the 80's and 90's GM front end alignment didn't last long and the front tires would wear poorly. I used to get about 25k out of front tires. rotating the tires would give you 4 bad tires in about 40k. without rotating I got 70k out of the rears and just replaced the fronts when needed. worked out better economically not even counting the cost of having it done. just a thought
#8 | |
![]() ![]() ![]() ![]() ![]() Drives: ABM 2399 Join Date: Oct 2018
”Blue”ABM #2399, 2010 2SS/RS: GM GFX, GM Heritage, GM dovetail, Silver Ice Rally stripes.
‘87 IROC-Z all original unmolested with 50K miles. |
#9 |
Sporting Foole
Drives: 2010 Camaro SS Join Date: Sep 2019
if I would stop rotating my rears so much every time I drive the damn thing they might last longer?
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 SS-RS Join Date: May 2011
^^^ lol, yep. Tire rotation equals smoke show!!!
Thread Tools | |
