![]() Drives: 2010 Camaro 2SS/RS A6 Join Date: Jul 2021
OBD2 Splitter
Has anyone tried an OBD2 splitter in order to feed two different devices? I have tried two different splitters to feed my after-market HUD as well as my iDatalink Maestro. When I have both devices plugged in and receiving data, the HUD glitches. When I disable the feed on the Maestro (there's an option in the settings), then the HUD works normally. this has occurred with both splitters I've tried so far. Wondering if there is a splitter that allows both devices to receive OBD2 without interference or glitching.
2010 2SS/RS A6. GPI SS3 VVT Cam, 228/246 / AFM Delete / Circle D 4C 36-3800 Stall / Stainless Works LTHs, High Flow Cats, X-pipe, Borla Pro XS Mufflers and Quad Tips / Vararam CAI / Soler 95mm PTB / AAM 3.91 gear / GPI Ported Heads / GPI Ported Rod Mod Intake Manifold/ Smith Bros. Trunnions / GPI 5/16" hardened push rods, 7.425"/ Chevrolet Racing Lifters / Melling 10355 Oil Pump / Powermaster XS Torque Starter / Derale Xmsn Cooler / 1LE Suspension Upgrade System / BMR Strut Tower Brace, Trailing Arms and Toe Rods / Powerbond 25% UDP / Mishimoto catch can / iDatalink Maestro.
![]() ![]() ![]() Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
There is another thread that this was tested on and I think the conclusion was that only one device would work at a time.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, SLP loudmouth exhaust, elite engineering catch can and many other things.
![]() Drives: 2012 SS Join Date: Dec 2021
I have done it, but usually one of the devices does not function to full capacity when both are plugged in at the same time.
2012 Camaro SS
BOOST OR BUST
It was my thread OBD2 Port Splitter Product Question
One member told me to not bother because only one would work at a time and that I’d be better off buying the pins and wiring another connector. It was a $15 experiment so I decided to purchase the splitter anyway and I’m happy I did. Both my CarLock device and Aeroforce Interceptor gauges work simultaneously. I liked it so much I got a second splitter for my Jeep Grand Cherokee also to run a second device. Here’s links for the two I purchased on Amazon that worked! •bbfly-B4 •bbfly-A9
Batmaro=The Bane of My Existence ⠀⠀⠀⠀⠀ ⠀ ⠀⠀⠀⠀⠀⠀ ⠀ ⠀ ⠀⠀⠀ ⬋LIKE AND FOLLOW THE BUILD ON INSTAGRAM⬊
BUILD STATUS: LOADING BOOST . . . |
They just DON'T work
Thread Tools | |
