01-10-2022, 07:55 AM | #1 |
Drives: 68 Nova SS 2013 Camaro 2SS RS Join Date: Sep 2021
Charge Battery
Hi,
Quick question: Can you slow charge the battery by hooking charger to Pos terminal and ground post in engine compartment???? Ken |
01-10-2022, 08:02 AM | #2 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
Yes
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
01-10-2022, 08:04 AM | #3 |
YEPPERS...
01-10-2022, 08:05 AM | #4 |
Hi
Thanks,
Ken |
01-10-2022, 09:43 AM | #5 |
KaBoom1701
Do it all the time with my ZL1.
Mods:
01-10-2022, 11:01 AM | #6 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
Mine does not always like that anymore. I'll be improving the grounding from the battery to the body, but if I do it now it will only go to about 13v on the charger and if I ground to the block it will go to 15v.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
