06-23-2016, 10:00 PM | #1 |
Drives: 10 ss/rs ls3 Join Date: Jun 2016
Diagnostic screen in camaro says check left rear turn signal
So message pops up I have the replacement bulbs changed them, and it's still says to check left rear turn signal which flashes faster than normal. I figured it was like normal and bulb was out. Amy help is appreciated thanks ks
06-23-2016, 10:02 PM | #2 |
A couple of tabs of Ritalin in the gas tank should do the trick.
06-23-2016, 10:04 PM | #3 |
Ret AF, cancer survivor
Drives: 2013 Camaro 2SS/RS & 2006 Corvette Join Date: Jul 2015
If the light is working, but is blinking faster, I'd check the relay.
06-23-2016, 10:59 PM | #4 |
Drives: 2010 2SS/RS M6 Black on Black Join Date: Jan 2010
Did you replace the standard bulbs with LED's? If so, you need a resistor in the line as they will flash faster due to the lower electrical resistance.
Meh
06-23-2016, 11:53 PM | #5 |
06-24-2016, 12:38 AM | #6 |
06-24-2016, 10:36 AM | #7 |
Drives: 2013 2SS/RS Rally Yellow Join Date: May 2014
I will take a stab... have you checked your front bulb as well. I know the car is saying check rear... but on some cars... you lose the front bulb and the back will run faster. (or vice versa)
2013 Camaro 2SS/RS-6spd- Rally Yellow / AGP Twin Turbo 2015 Challenger Hellcat-6spd- Sublime I think I see a trend here.... |
06-24-2016, 11:40 AM | #8 |
Drives: 2011 Inferno Orange Camaro 2SS/RS Join Date: Nov 2011
Make sure the bulb is good and check the wring to the sockets. Switch the bulb with the other side if you need to. Could be the front bulb as mentioned. I doubt very much its the relay.
Mine does that from time to time but that is because I have mine wired sequential and I had them running a tad too slow. Last edited by Rainbow1616; 06-24-2016 at 12:05 PM. |
06-24-2016, 01:34 PM | #9 |
Drives: 2017 2SS, 2023 3LT RS, 2011 2LT RS Join Date: Aug 2014
Back in the day, we would cut the grounds on our blinkers to make them blink faster, check your grounds.
06-24-2016, 01:52 PM | #10 |
06-24-2016, 04:13 PM | #11 |
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3 Join Date: Jun 2010
Blinker fluid is low on that side.
06-24-2016, 04:58 PM | #12 |
Destroyed by flooding
Drives: Wife's car Join Date: Mar 2014
Blinker fluid is good stuff!
https://www.google.com/url?sa=t&rct=...-asDwloekph3uA
06-24-2016, 07:10 PM | #13 |
So front bulb and rear bulb light up and flash just really fast am lost on what it could be
06-24-2016, 07:44 PM | #14 |
Did you check the relay ... that's still what it sounds like to me.
Thread Tools | |
