Old 08-08-2017, 01:56 PM   #1
rrrocketman
youtube.com/c/ChrisCamaro
Drives: 2013 Camaro SS w/ NPP and Hi Wing
Locating a suitable vacuum line
I just got my BOV and it comes with a plastic tee and rubber hose that's all 1/8" (that's what it looks like). Reading other threads on this topic, I see most people cut into their brake booster but that's a huge 3/8" hose. 1) I'd rather not cut into something that big and that important for safety and practicality reasons and 2) it requires some sort of adapter to shrink the tee down to 1/8, which means more fittings I have to search for and buy.
Anybody know of a 1/8" vacuum line that can be tee'd ?
rrrocketman is offline   Reply With Quote
Old 08-08-2017, 04:22 PM   #2
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Drives: 2010 Camaro SS
Tap into the back of the intake manifold. There is a small nipple next to where the brake booster hose attaches. Looks like you have NPP so there should be a hose there.
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray
480 RWHP 452 RWTQ + Nitrous Express 150 Shot
LSX Camaro is offline   Reply With Quote
Old 08-08-2017, 07:36 PM   #3
rrrocketman
Aha! Good man!
(Thank God for nipples)
Old 08-08-2017, 07:51 PM   #4
rrrocketman
Err.. I found a curious looking thing behind the last coil on the driver's side valve cover. It's covered with a rubber boot that has a flat grip handle and is very easy to pull off. Underneath looks like a 1/4" pipe. Is that what you were talking about? I didn't see anything else.
Old 08-08-2017, 08:58 PM   #5
blake-b
blake-b's Avatar
Drives: 2009 ZR1
No, that is a blocked off port for PCV. The one he is talking about might require you to take off the manifold to get to.
Old 08-09-2017, 07:25 AM   #6
jeff657756
Drives: 2014 SS 1LE
You will have to take the intake manifold off to get to that nipple above. I believe 1/4" ID hose will fit over it. 1/8 wont be big enough so you may need special tee 1/4 to 1/8. The driver side nipple near the TB is where some guys get vac references when they go boosted (red nipple in pic above on left side). That's what i used for my wastegates/BOV/hobbs switch, booster controller. but you will have to do something with the evap line. I just route mine to vent down near the k member. I used the nipple on the back of the intake manifold for my fuel pressure regulator.
jeff657756 is offline   Reply With Quote
Old 08-09-2017, 08:43 AM   #7
rrrocketman
Looks like it's right at the ass-end of the manifold. Does it not protrude and stick out so one can access it? If not I might just cut the hose going to my exhaust and tee it... provided that's accessible... and provided it's rubber.
Old 08-09-2017, 09:21 AM   #8
rrrocketman
But if I were to tee it to a BOV, there's no leak in the system (it simply goes to a diaphragm) so wouldn't it continue to function normally?
Old 08-09-2017, 09:21 AM   #9
CGbambam
Drives: 2011 Camaro 2SS
Why don't you just tee of from right behind the throttle body? ( where the yellow/red caps are on in the picture)
CGbambam is offline   Reply With Quote
Old 08-09-2017, 11:45 AM   #10
rrrocketman
I can... if there's no problem doing that.
Old 01-03-2019, 03:08 PM   #11
Audy
CAMARO RS M6
Audy's Avatar
Drives: Camaro RS v6 2014 M6
Smile How to install vacuum lines gauge to camaro lfx ?
I want to install vacuum lines gauge to my camaro lfx but I don't have force induction. just want to put vacuum gauge I don't know what line to use somebody has this project done?
Audy is offline   Reply With Quote
