08-18-2018, 05:30 PM | #1 |
Drives: 2014 Camaro 2SS 1LE Join Date: Mar 2018
Need some help identifying a possible vacuum line
There is a hose or vacuum line that connects to the tube with the green connector (see my pic for more detail) as pictured. I believe this connects to my intake manifold, and it's right next to my brake booster vacuum line. I had the rod mod done by GPI, but they sent the intake back without this tube attached. Anyone with some mechanical knowledge know what I'm talking about?
Sent from my SM-G930V using Tapatalk |
08-18-2018, 07:12 PM | #2 |
Hotwheels
I believe that's the NPP vacuum line
08-18-2018, 07:39 PM | #3 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
Yes, 2 lines at the rear of the intake. One for the brake booster and the small one is for the npp.
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
08-18-2018, 08:03 PM | #4 |
Great, thanks for the clarification! Any harm in running the car with this vacuum line disconnected? I already have the fuse pulled on my NPP
08-18-2018, 08:49 PM | #5 |
Hotwheels
Since that is not the source of vacuum it should be no issues.. Just cap that line so nothing gets in it
Sent from my SM-G955U using Tapatalk
01-03-2019, 07:12 PM | #6 |
CAMARO RS M6
Drives: Camaro RS v6 2014 M6 Join Date: Jan 2019
How to install vacuum lines gauge to camaro lfx ?
I want to install vacuum gauge, but I don't know what line to use for vacuum line for the vacuum gauges somebody help me plesase
