Old 06-10-2018, 01:38 PM   #1
john2012camaroSS
john2012camaroSS's Avatar
Drives: 2012 Black SS
Coilover install
How many approximate hours of labor would be fair for a mechanic to charge for a front and rear basic coilover installation.
Thanks
john2012camaroSS is offline   Reply With Quote
Old 06-10-2018, 07:57 PM   #2
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
It's relatively fast man...I could probably swap them in under two. I'm not a pro by any means, but I do have power tools.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 06-10-2018, 08:12 PM   #3
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
Prolly be roughly 4 hour job. Remove old suspension, install coilovers, and set ride height/rebound/compression (if your coil overs have all those options).
More to come.
Black_SS10 is offline   Reply With Quote
Old 06-11-2018, 09:31 AM   #4
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Four hours sounds about right. I did it in about 6 in my garage (BC Racing ER Series), and needed a little extra time to figure out how to mount the remote rez's for the rear.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
