Old 05-11-2014, 07:38 PM   #1
bcguy
bcguy
bcguy's Avatar
Drives: 2011 ss/rs m6
fuel pump access hole
he guys can someone point me in the right direction for the measurements for the underseat cut out for the fuel pump .tried the search function and cant seem to find it.yes I know to drop drop the rear to do this but I want this accessable thanks
Agp 62/66 ,lsx 427. , Callie's ,diamond ,all pro ,American racing ,I'ds130s,102 intake and throttle body,etc .fore triple , Turbo 400 level 5 , b and m pro , dss carbon fiber , dss ford 9 inch with strange pumpkin,3.73 ratio,1400 hp axels,boost and air fuel pillar guages. Weld rts 17x10 and 17x4.5 with m and h drag radials and skinnys
bcguy is offline   Reply With Quote
Old 05-11-2014, 11:41 PM   #2
blake-b
blake-b's Avatar
Drives: 2009 ZR1
No measurements in pictures but with the floorpan "landmarks" you should be able to get it right.
http://www.camaro5.com/forums/showpo...9&postcount=26
Here's the whole thread:
http://www.camaro5.com/forums/showth...=256182&page=1
He used a lock ring tool and said the hole (square) has to be 7.5" x 7.5" to have room for the tool.
From same thread but with some instructions:
http://www.camaro5.com/forums/showpo...4&postcount=94
Another thread:
http://www.camaro5.com/forums/showthread.php?t=229467
Old 05-12-2014, 12:07 AM   #3
bcguy
bcguy
bcguy's Avatar
Thanks. I had found them after posting. Appreciate the help
Old 05-12-2014, 12:27 AM   #4
blake-b
blake-b's Avatar
Drives: 2009 ZR1
You're welcome. If it were me, I'd cut the top edge (towards rear of car where the raised sections are) a little longer so a flat piece of metal would sit flush and not have to deal with the raised ribs. Even if it is where it starts to curve up, it will be easier to form that curve than try to put rib reliefs in the plate if you are concerned with it sitting flush (It would bother me even knowing no one would ever see it)
