Old 08-23-2011, 02:31 PM   #1
etdrag
Drives: 2010 Camaro SS
ac blowing hot out driver side
Have any of your cars started blow warm out out the driver side and cool air out the passenger side? There is a way to reset the hvac control module it seems to work cant say for how long but you don't have to disconnect the batter there it is
Place the ignition switch to the OFF position.
Connect all previously disconnected components.
Remove the HVAC control module fuse for a minimum of 10 s.
Install the HVAC control module fuse.
Ignition ON.
Wait 40 s for the HVAC control module to self-calibrate.
then start and turn a/c on turn car off the turn back on with a/c on i can't say this is permanent fix but it helps for at least 20 key cycles so far.
Better than replacing the blend door actuator or control module if you are out of warranty like myself.
etdrag is offline   Reply With Quote
Old 08-23-2011, 05:54 PM   #2
proj3ktpat
Drives: 2010 Camaro 2ss/rs
Yes! This happened to me a while ago, and a little while afterwards a belt started squeaking under the hood followed by the a/c going out entirely. I took it to the dealer and apparently a belt was installed backwards from the factory or something. I don't remember the exact details. Idk whether or not it was related to the driver side blowing hot for a while or not though...
proj3ktpat is offline   Reply With Quote
Old 08-25-2011, 12:37 AM   #3
etdrag
Well its not a permanent fix it goes back to blowing hot but until i can find a dealer that will warranty it with no issues ill just keep resetting.
Old 08-25-2011, 11:56 AM   #4
yotaman96
yotaman96's Avatar
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6
Maybe you have a rare dual climate control option???
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2002 Trans Am
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 08-25-2011, 12:11 PM   #5
CrazyDan
Drives: 2011 SS
This has happened 3 times in my 2011
CrazyDan is offline   Reply With Quote
Old 08-25-2011, 03:11 PM   #6
BowtieBelle
They see me trollin'...
BowtieBelle's Avatar
Drives: 217 ci of fury; Chauffeured by SS
Yeah, it's the damn actuator door thingy. Did it in my Silverado and I did the reset deal because it's expensive to replace and the labor is ridiculous as you have to rip the dash out...
"Never race anything you can't afford to light on fire and push off a cliff." -CamaroSpike
2011 Custom LT/RS: Bella's Build Thread
BowtieBelle is offline   Reply With Quote
Hot air Intakes -By Kenne bell ADM PERFORMANCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 66 02-08-2011 08:33 PM
Where we are coming from (check inside) ljustin293 2010 Camaro5 Fest (I) 106 05-12-2010 11:31 PM
Camaro 5 Fest Drivers or Spectators garcmol 2010 Camaro5 Fest (I) 427 04-23-2010 02:32 PM
CLOSED - Driver Signup for the 1st Annual Official Camaro5Fest (April 16-18, 2010) GTAHVIT 2010 Camaro5 Fest (I) 923 03-19-2010 11:56 PM
