#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Road Course/Track and Autocross
Old 06-04-2018, 04:11 PM   #1
Badgerbimmer
Badgerbimmer's Avatar
Drives: ZL1 A10
Consensus on Eagle Supercar 3 camber
Do we have enough experience to have a consensus on the ideal amount of negative camber for the track for the Eagle Supercar 3 tire?
My rides:
2017 Camaro ZL1 A10
2015 Jeep Grand Cherokee Diesel
2012 Audi S4
1992 Porsche America Roadster
1990 BMW 325Ic
Badgerbimmer is offline   Reply With Quote
Old 06-04-2018, 04:50 PM   #2
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
There is no one magic alignment. It depends on your particular tire wear. That'll account for your application.
What have you tried so far, and what is your tire wear feedback?
2017 "M1SS1LE" in Hyper Blue w/PDR
Ryephile is offline   Reply With Quote
Old 06-04-2018, 05:35 PM   #3
Badgerbimmer
Drives: ZL1 A10
Don't know, haven't tracked the car yet. Installing Moreno camber plates, was simply going to go with -3.0 or -3.25. Many performance tire manufacturers provide guidance on what tire pressure hot and what camber their tires like. I have not been able to find that information for the Goodyear's.
My rides:
2017 Camaro ZL1 A10
2012 Audi S4
1990 BMW 325Ic
Old 06-04-2018, 09:41 PM   #4
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Originally Posted by Badgerbimmer View Post
...simply ...
-3.25 is rather massive and will tramline significantly. Where did you see that kind of camber is a good idea for your first track day?
You car came with a Performance Supplement booklet that has a GM recommended "Track" alignment, along with suggested cold and hot tire pressures. I suggest you start there, as it's a solid baseline. You don't need the Moreno plates to achieve it either.
A little slice of advice; no amount of camber will provide flat tire wear on the stock FE4 suspension, as the dynamic camber loss and camber curve is non-conducive to good tire wear. Once you get acclimated to the car and reach its maximum pace, roughly -2.6 to -2.8 deg front will be about right to wear both the inboard and outboard shoulders simultaneously. If you're not routinely in HPDE advanced group or better, then you won't need that much camber to reach balanced tire wear. This is why I said earlier the best alignment is one that *you* find wears the tires as evenly as possible.
Old 06-04-2018, 11:12 PM   #5
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
Where does one purchase Moreno plates? Their website was down tonight. I just wanted to research them.
ninetres is offline   Reply With Quote
Old 06-05-2018, 07:30 AM   #6
Badgerbimmer
Drives: ZL1 A10
Website: www.gen5diy.com
My rides:
2017 Camaro ZL1 A10
2012 Audi S4
1990 BMW 325Ic
Old 06-05-2018, 07:33 AM   #7
Badgerbimmer
Drives: ZL1 A10
I ran -3.6 front, -3.0 back in my last track car. Most manufacturers suggest at least -3.0 for their track oriented tires. The suggested camber settings are what you can in theory achieve with a stock set up, not necessarily (or likely) the best set up.
My rides:
2017 Camaro ZL1 A10
2012 Audi S4
1990 BMW 325Ic
Old 06-05-2018, 10:31 PM   #8
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
I’m seeing perfect temps across the board with these tires at -2.7.
I also have a set of new Moreno plates that I’ll sell. Never used, bought for my last car. Send me a PM if interested.
seanblurr is offline   Reply With Quote
Old 06-06-2018, 07:44 AM   #9
Badgerbimmer
Drives: ZL1 A10
Thanks. I already have a set.
I will also take a look at setting the "strut camber" to full positive and achieving say -3 with the camber plates, which I assume is like other camber plates and pulls the top of the strut inboard, this should pull the wheel away from the strut and presumably allow a bigger wheel fit without spacers.
My rides:
2017 Camaro ZL1 A10
2012 Audi S4
1990 BMW 325Ic
Old 06-06-2018, 08:40 AM   #10
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
Gen5DIY lists those plates as "out of stock" with mid-August availability predicted.
Something to consider . . . if you're going to run a max +camber setting at the knuckle for tire clearance, camber plates may not have enough range to get you all the way to -2.7°. FWIW, you don't need quite as much tire to strut clearance at mid-sidewall height as the amount the tread and shoulder moves laterally. For most tires, anyway.
Norm
'08 GT coupe 5M (the occasional track toy)
'19 WRX 6M (the family sedan . . . seriously)
Norm Peterson is offline   Reply With Quote
Old 06-06-2018, 09:10 AM   #11
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Originally Posted by Norm Peterson View Post
...if you're going to run a max +camber setting at the knuckle for tire clearance, camber plates may not have enough range to get you all the way to -2.7°...
It's no problem. You don't need to go max positive at the knuckle to get plenty of wider-than-stock tire clearance.
Old 06-06-2018, 10:40 AM   #12
Badgerbimmer
Drives: ZL1 A10
It will be interesting to see how it works out. When we are on the rack we will test it with the rear wheels, albeit that may not be ideal offset for the front..... It would be handy to have the same wheel and tire on all four corners to enable rotation to even out the track wear and presumably gain some grip.
My rides:
2017 Camaro ZL1 A10
2012 Audi S4
1990 BMW 325Ic
Old 06-08-2018, 07:59 AM   #13
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
I'm currently at -3* front and -1.5* rear on my G3R's for a autocross set up.
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap
ICTsccaCamaro is offline   Reply With Quote
Old 06-08-2018, 09:19 AM   #14
Norm Peterson
Thanks. I was hoping for everybody's sake that that was going to be the case.
Norm
