02-04-2017, 07:37 AM | #1 |
Santos
Drives: 1SS Blk 6M ECS 1500 Join Date: Jul 2007
ECS BAP & 60lb motron injectors
Hey guys I'm trying to find out if anybody can tell me how muche hp the kit from ECS will support, I've done a few searches and so far I've seen the bap will support 1000-1200 &possibly 650 for injectors, I'm getting ready to order my kit Monday and want to make sure I don't need anything else, thanks guys
02-04-2017, 07:46 AM | #2 |
BAP is nothing more than a voltage booster that may add 10% flow to your current fuel pump. So if you have a fuel pump that will do 500 it may bump that up to 550.
So "1000-1200" is a stretch. Sure on a 1100hp dual pump setup, a BAP may let it support 1200, but saying a BAP supports 1000-1200 is not even close to correct.
Nick
Corvette Z06 -1200ish rwhp |
02-04-2017, 08:03 AM | #3 |
Santos
gotcha, ya thats what i figured, that was from another forum which i dont go to often and def sounded way to high. i have the stock ss fuel pump so not sure what thats rated at, have been told to just get the ZL1 pump and then i should be ok with KB BAP and the 60# injectors?
02-04-2017, 04:11 PM | #4 |
Drives: 14 1LE Join Date: Jul 2013
do yourself a favor and do the fuel system first.. just put down 767 to the wheels with the ecs kit, unrestricted, on e85 with STOCK cam. Had fueling issues on stock system while i was restricted.
02-04-2017, 08:03 PM | #5 |
Well to be honest it put down over 800.. 767 was when they added heat and humidity
